D16y8 swap - How do I wire VTEC using a DX ECU?
Ok, I've searched and searched and couldn't find what I was looking for. I just traded and got a 96 DX that they swapped a d16y8 into. The girl I traded bought another ecu but its the same exact as the stock dx ecu. I know there is a way to wire the vtec solenoid without getting a different ecu. If someone could please either link me to what I am searching for or could help me out it would be appreciated greatly.
Thanks,
Lissa
Thanks,
Lissa
Re: D16y8 swap - How do I wire VTEC using a DX ECU?
You could run it on the non-vtec ecu for emissions testing if you have to. This is what most people do in this situation. And then just hook up a P28* with a conversion harness to enable VTEC. The Y8 will still run fine on the Y7 ECU, it will just be held back a little performance wise.
*instead of a P28, any Civic or Integra 1992-1995 ECU can work if certain parts are added. A P2E or whatever it is for the Y8 would be the "proper" way to do it, but the OBD1 ECU will let you tune it far easier and cost about the same.
Thanks, to all that replied and no the state i live doesn't require any kind of inspection at all. I can get the ecu cheap, I just have lack in my funds lol. I know i've seen people wire them by splicing the harness and wiring it to the non vtec ecu. I know I can take the two I have a place the pins in one to the other but I don't want to go through all that either. I will just get a p2p eventually. This is my first ob2 civic, i've had an eg and a ej1. Someone also pointed out that I have a em1 front end. I am just thankful to be a honda owner again. It is all I know I traded a DSM for the civic.
Im new to this site it would let me start a new post but anyways can anyone help me out i have a 96 civic dx and i am in the process of doing a y8 swap out of a 99 ex im using the engine and tranny and my car was already 5 speed. Do i need to use the y7 or y8 harness and the dx or ex ecu ? Can some 1 please give me instructions on how to wire my engine and what i should use would be much appreciated my email is randymink18@yahoo.com
Technical Hero
You can use either one. With the Y7 you'll have to rewire the IACV to 2 wire, add VTEC wiring, add knock wiring and possibly extend the secondary O2 if you don't use the Y7 manifold.
With the Y8 it'll be plug and play you'll just have to wire the secondary O2 directly to the ECU.
http://ff-squad.com/wp/?p=395
Use a 96-98 P2P ECU from a 5 speed model Civic EX. Reuse your distributor for plug and play.
cloven
02-08-2006 11:47 AM
