car wont start, battery wiring?
i just bought a new battery about a week ago, today after work i turned the key and dash lights and everything came on, then it just died completely after i tried to crank over the engine. I tried jumping it and had no luck, i jiggled the terminals and the dash lights came on, but then died again when i went to crank it over. Does this sound like a battery, or some problem with the wiring to the battery?
Re: car wont start, battery wiring?
http://i267.photobucket.com/albums/i...cture_3412.jpg
If something is wrong then where do i go from there?
Well since it is wired into the ignition wiring, I followed the diagram exactly though and it works as it should.
Soldered, didnt use heat shrink wrap though, just electric tape, wrapped tight. It seems to change when i move around the terminals though, but when go to crank over the engine it loses all power
i will get strong electric power it seems, fuel pump sounds normal, But then as you turn the key to start it the whole dash goes black, like no more power at all.
Pagoda
09-15-2014 09:30 PM
97itr86
12-26-2004 07:07 PM
