96 4dr door to cabin harness clip
Old 02-29-2012, 05:47 PM
azndough's Avatar
Default 96 4dr door to cabin harness clip
hey i know the is a well beat horse but after lots of searching i have yet to find the pinout for the clip at the drivers door i had lots of wires break off and they have broke off in the clip with no remnants of wire to go from , so a link to the wiring pinout would be awesome thanks !
Old 02-29-2012, 05:58 PM
Lil Gnome's Avatar
Default Re: 96 4dr door to cabin harness clip
Which door? What color's the connector? More info, pics would be sick.
Old 02-29-2012, 06:05 PM
azndough's Avatar
connector is grey , and its for the drivers door ,
Old 02-29-2012, 06:08 PM
Lil Gnome's Avatar
Do you know what the connector powers?
Old 02-29-2012, 06:25 PM
96dxcrapbox's Avatar
is this for the harness in the door? or the floor harness? either way just go to the junkyard and get another plug, splice it in and go just make sure the plug is for the same year as your car. my floor harness was crapped out when i got it.
i could not find a pinout for the doors but a wiring diagram for the doors and the mirrors helped out alot. if you have your old plug and the new one side by side you can just match up the wires. will be fixing my plug this weekend.
if its for the door it would be easy enough to just replace the door harness it is not that bad .
Old 03-01-2012, 04:07 AM
azndough's Avatar
Post Re: 96 4dr door to cabin harness clip
all i need is the pinout for the main door harness at the plug in the jamb , it powers, windows , locks and mirrors , not tryn to be an *** but its an lx ! has power everything minus a sunroof ! i need to roll my windows down im a smoker
Old 03-01-2012, 07:24 AM
good luck finding one post it up here if you do
Old 03-01-2012, 07:51 AM
O.G. triple O.G.
NVturbo's Avatar
If the pins are broken off, your best bet is to get both connectors (with ample length of wire) from your local junkyard and solder the wires. I had to repair mine in my old '93 Civic 4dr.
Old 03-01-2012, 04:55 PM
azndough's Avatar
well i over read some one asking some one else if they wanted it posted but the guy said he didnt need it so the other never posted it , if i pull the clip out of the other car im going to have the same issue al those car suffer from the same problems no sense in trying to resuse the same faulty wire set !
Old 03-01-2012, 07:51 PM
you are assuming every civic has that same failure alot do , but all? not the case.
imho it would be way easier to just install a new harness over trying to repair the pins in a broken plug.
but here knock yourself out. found it on all data. was a little lost using alldata but played with it today.
Old 03-02-2012, 02:46 AM
O.G. triple O.G.
NVturbo's Avatar
^ I hope you know that a new harness from Honda isn't going to be cheap. The OP's best bet is to solder in new pins(w/ wire attached) into the plugs.
Old 03-02-2012, 05:47 AM
i paid 8 bucks from a pick and pull for the same harness in perfect working order.
also i priced them from few local junkyards i use, 40 bucks delivered to my door
yup expensive.
Old 03-02-2012, 09:57 AM
motegicivic's Avatar
From honda the floor harness is over 100 bucks.
You can repin it if you have the patience.
GooseS2000
Audio / Security / Video
11-06-2011 09:03 AM
Terry36
05-08-2011 04:22 PM
Micemt
12-04-2007 11:04 AM
CaptivaBlue
10
02-27-2005 10:24 AM
Quick Reply: 96 4dr door to cabin harness clip
