main relay doesnt have power
Its a 99 em1
Yes i have searched.well my fuel pump wont turn on my ecu doesnt have power so i checked my main relay and it doesnt have a constat 12v wire it has a wire that gets power with ign on and a wire that gets power when cranking the car but it diesbt have a constant..now from what i read if it doesnt have a 12v constant my fuel pump or ecu wont get power.my question is where does this wire get power from and y doesnt it have power..ive checked all my grounds they are good...fuses are all good so im stumped where else can i look to try and get this thing fixed...also i ran a wire from my battery to my fuel pump to see if it primes and it doesnt,SHOULDNT IT prim with a direct power...someone help me on this i need my car running
Re: main relay doesnt have power
Its a 99 em1
Unplug the main relay, turn the key to ON(II), and then jump terminal 7 to terminal 4 (7-4). Does the fuel pump run? Do the same test for 5-4. Does the fuel pump run?
When i turn ignition on my fuel pump doesnt prim,also igp1 and 2 dont get power on my ecu plug.but the yellow/black wire on connector c101 has power
wire would be split in two, meaning no power. i would do a volt drop test to be sure. checking for continuity will only tell you that there is contact but wont tell you if you have power going through and how much. a DMM from any auto parts store will work, and also comes with instructions on how to do a volt drop.
