ITR sway bar on a civic
If I got an ITR sway bar, would it fit on a '98 sedan without problems? Would it fit into standard Civic mounting brackets? How thick is the ITR bar? I just have a stock swaybar up front (22mm)....would an ITR one be too thick with just a stock one up front? If so, would I just be better off with an Si 13mm one? Thanks for the help.
1 Post
Re: ITR sway bar on a civic (str8edgexx)
To mount the sway bar you need a few things
1. ITR bar
2. Si endlinks
3. Assorted bushings and D brackets
4. Beaks kit
The last on is basically a suggestion. If you mount the bar without using some sort of a kit, it will eventually rip out your subframe (not a good thing).
Go to http://www.beaksproducts.com.. he sells entire kits.
I recommend a 22 mil bar over a 13. Feels a whole lot better
1. ITR bar
2. Si endlinks
4. Beaks kit
Re: ITR sway bar on a civic (fowler)
If I got a complete Si swaybar set up, that would just bolt right on, right? Would I still need to get that reinforcement kit you were talking about?
i have an itr set up with the beaks kit and all you need for 200 plus shipping.
i can deliver like yesterday. i really need to get rid of it. i have never used it. i got everything from the factory. never been used!
thanks
thanks
dgdarien
10
03-30-2003 01:09 PM
nuspeed27
09-18-2002 11:01 AM
