engine help?
Re: engine help? (slow_a$$_si)
someone told me that there is air in the radiator hose? comments drag?
if it makes you feel better, squeze out all the air from the upper rad hose.
recheck all vac connections.
check engine light on?
Re: engine help? (SuperDragII!!!)
If there is air in the cooling system the coolant temp sensor can not do it's job. It wants to see a warm temp in the coolant to drop the idle. If air passes over the sensor it reads cool and confuses the ECU. As soon as it reads the hot coolant it lowers revs. That's why it fluctuates. Make sure to bleed and properly fill the coolant system. This will cure your woes no doubt.
JaguarS4R
Honda Civic (2001 - 2005)
12
02-28-2010 04:12 PM
