tein suspension. is it good?
Re: tein suspension. is it good? (95CivicSi)
can you please let me know some of those, and how much did you pay for the suspension?did you install it yourself?if a shop did it how much did it cost?i am just getting some ideas right now cause my civic is completely stock and i want to do suspension first....thanks
Re: tein suspension. is it good? (EKCivicRacer)
first off, installing suspension is easy. but if you got the cash, it is allot easier to have someone else do it. I got mine for $935 + shipping.
most of my information on this is heard from other people, nothing really in black and white. now i live in AZ, so rusting isn't a prob but i have read these things rust up fast. so i plan to just keep them sprayed with wd40 every month or so. i was also told they have a weak valving system in the strut that causes them to not have a very long life span. they are not marked, so unless you remember or write down what settings you have them on you can't tell where they are set. also a downside to that is, everytime you forget where you are you have to crank it to 16 and count back.
just the rusting and how delicate the valving is in them kinda makes me regret buying them knowing that in about a year (i drive ALLOT of miles) that these things are tost...esp a bummer knowing you blew a grand on them.
besides on that, they look like they are built very well, come with a dust boot, look all jay-de-emm and ****, and you can brag till you are blue in the face with them.
my next setup when these turn to jello will be Zeal B6s...heard they are thuff and take allot of ****.
[Modified by 95CivicSi, 9:34 PM 5/14/2002]
Re: tein suspension. is it good? (RexB16)
i am talking about the boots that cover the shaft so dirt doesn't get into the seals, NOT the little rubber caps you dumbass mule.
can't we all get along?
I have teins. I have owned everythign from intrax and stock shox on a civic 1995, to eibach sportlines with tok blues.
It is so night and day, its an insult to even compare. It's like dating your fat neighbor then stepping up to a supermodel. The sex appeal and body ride just doesnt compare...THEY R SO TIIIIIGHT.
but seriously, no rubbing, no bottoming out, I have a 96 ek with a apex n1 exhaust that **** hangs real low and when i had my car slammed the exhaust scraped with friend in it, but on the highway and fast bumps the teins do all the work, My car is very neutral handling now with pirelli p7000.
okbyeseeyoubye
okbyeseeyoubye
Re: tein suspension. is it good? (pkek)
okbyeseeyoubye
okbyeseeyoubye
we know eachother. rexb16 ownes the ugliest car ever made by man. its my job to give him a hard time about it.
spraying the crap out of them with wd-40 will solve any rust issues in the future or no? just bought the SS's for v6 accord, thought i chose the right suspension, guess not if they're gonna be gone in a year with these crappy roads and crappy winters in NJ
the idea is, if you keep oil on them and stop the outside air and moisture from touching the metal it *should* prevent the rust. wd40 is one solution, but i am sure any light oil will work.
I have Tein NA's. The best purchase i have ever made. They are Night and Day like someone said earlier. Highly recommened. I have had no problems what so ever w/ them. I have no idea what the other dood was talking about. And yes they are completely rebuildable. Get them and enjoy
Koni's setting are not marked, Zeal settings are not marked, Mugen settings are not marked.
Don't crank it up to 16 cause you have 24 total clicks. you crank is DWON to 1 and up from there. Counter clockwise gets you to full soft and you go UP from there. TEIN's can be rebuilt to allow for 24 settings but in stock form only the first 16 do anything.
TEIN's are great suspension setup and for the cost you won't find anything better. SS's for the civic are really affordable now. Rusting is not all that big of an issue as like I mentioned I had a set for 2 years with nothing like that. I am in Tennessee so I don't see much snow and only small amounts of salt but I do see my share or rain and humidity.
Just my observations.
Re: tein suspension. is it good? (Asahi)
this is also the first time I've heard about weak valving in Teins. Never seen any probs w/ that. As for rust, if you live in a wet, cold, or salty area, spraying some wd40 or anti-seize will keep rust off (as already mentioned). Also, most ppl think all Tein's have this issue, but it's only their lower line (SS, HA). Their higher lines (RA/RE/RS/N1) are all made of full aluminum and have no rust issues. FYI, Zeal B and B2 are also made of mild steel, just like Tein SS and HA, so they'll have the same issues.
Re: tein suspension. is it good? (Spoon1)
love the way Teins perform also you could get them with out p/bolt
mounts for $900.00
mounts for $900.00
$900 what model and where?
As for the rust, go to a marine shop(boats, engines, etc) and buy a spray called T9.
Use it once a year on anything and it will not rust. It's kinda expensive ($10-$15 a can) but well worth it. I live and drive on the beach so I know it works.
As far as the best prices, I called just about every dealer on teins list and found the best prices in austin, texas. There were a couple shops that were going sell me the RE's for $1400 + ship. I don't know about the ss/ha but since everyone else wanted at least $1800 for the REs, the ss has to be pretty cheap.
Re: tein suspension. is it good? (PrOjEkT-CiViC)
i emailed them about the rebuilds:
Date: 5/15/02 5:18PM
Subject: Re: rebuild
Brian,
For basic overhual of the SS Damper will run you $75 per damper. If
you want the basic overhaul plus revalving of the dampers, it will cost you
$100 per damper.
Staff @ TEIN U.S.A. INC.
http://www.tein.com
Tel: 562-633-7387
Fax: 562-633-7291
Brian,
$100 per damper.
http://www.tein.com
Tel: 562-633-7387
Fax: 562-633-7291
turbopanda
11-17-2004 09:27 AM
