Check engine light from test pipe
How do I stop the check engine light from coming on after installing a test pipe on a '00 Si? I'm getting tired of pulling the fuse to clear the memory from the ECU & radio.
Re: Check engine light from test pipe (sivicman)
wrap that o2 sensor in aluminum foil works for some people.
there is an o2 simulator that someone made and a lot of people have been using. The guy is a moderator for ClubSi and knows his ****. Do a search on there. I know it works. Mike
Gut I met at Buttonwillow on Friday used some foam rubber and wrapped the second O2 with that. Another guy just had the sensor taped to his floor inside the car with no wrapping. Both people ran all day at the track for at least 2 hours and no codes. Obviously these extreme solutions have worked.
Good luck,
Jayson S.
Good luck,
Jayson S.
Pure R Racer
11-28-2001 06:33 PM
ActiveAero
06-18-2001 07:02 PM
