HX model
HX model
Hey guys I have a HX and I've hardly seen any others!! Where are they and why dont they have many aftermark parts, e.i, I see millions of parts for the EX, LX.... but no HX!! How come???
Re: HX model (WannaBFast)
Im not going to be swapping because I dont got the money but i am looking for a new suspension, intake, exhaust, etc..I havent seem aftermarkets for HX.
Re: HX model (acme)
Re: HX model (GoLowDrew)
Actually its NOT the same stuff as any of the other civics. Its most common to an EX but the engine is the VTEC-E. I am having a hard time with an exhaust because I want a full catback but about the only thing available is HKS, too ******* expensive for me when I want to swap out my engine next year....and they won' tbe compatible then, and Thermal R&D which I will prob op for unless I go with an axel-back which I won't. But nothing is the same, different cold air intakes, AEM and Ingen do make one.. Umm suspension is same, but with engine bolt ons you get iffy on alot of stuff. Make sure you double check everything before you order, call the place talk it over and if they are like uhh I don't know - then I would be wary......
Re: HX model (BrandonClaps)
his door handles don't seem to be painted
Re: HX model (BnEiAkUiTcY)
The exhaust you have to get an EX and it will work, EX header must be used also with ex cat becuase HX cat sits up front of the block, intake is the same as ex, best thing to do is swap an ex tranny on it. The suspension is the same as EX, brakes are the same as LX.
Re: HX model (boostincivic)
i got a 1998 HX.
best 1/4 of 15.6@86 w/ just intake, muffler, short shifter, disconnected a/c p/s amd removed rear seats
[Modified by bretx0r, 7:41 AM 5/19/2002]
[Modified by bretx0r, 7:43 AM 5/19/2002]
Re: HX model (Troy)
I am a girl, mine is a HX - you can tell by the unpainted door guards, door handles and rear license plate area. I am the 2nd owner and I believe it has to be aftermarket sunroof. Its pretty tight though and does not leak.
As far as buying an exhaust setup for the EX, I don't believe it will work with some of the piping? But instead of spending more money you might want to go with what works for your car..
Troy - I think I wrote you and asked about your car like what you had on it, but you never wrote me back.
Also the black one is niice - what do you have done to yours?
yep those would be altezza's - you wanna buy them? I want some all red/white tails if anyone wants to sell them to me!!
altezza =
red/white =
Re: HX model (Spade)
the guy that said use the EX header, cat and exhaust was right. thats all u have to do. and all civics 96+ will have the same suspension. and u can use the intake for an EX also. its all the same. the engine is just a little different.
