Slotted brakes
Re: Slotted brakes (stspj)
Yes there red. The kit was from landspeed racing it was the sport kit ( 2 rotors, and pads). The racing kit has 4 rotors, pads, and stainless steel brake lines. Sport kit was 200 and the race kit was like 425. Powerstop powerslot rotors and pbr pads. I checked on the warping issue. The slotted and drilled rotors can warp more easily because of the lower amount of actual metal in the rotor. Although you can warp any rotor if you really try.
[Modified by stspj, 7:08 PM 5/14/2002]
You could have just as easily bought some Hawk HP Plus brake pads, turned the rotors and had great braking? Just curious on the decision.
Re: Slotted brakes (Driven)
look in summit ad,says cross-drilled stay 200 degrees cooler than stock rotor.also lighter weight and resists warping 3x's than stock.
Re: Slotted brakes (geechieracer)
IMO i'd stay away from the cross drilled not needed at the speeds your going to be going... especially with the pads your runnin'. As far as slotted...eh
the better the caliper / pad the better the braking the lines make a significant difference if you go that far.
Re: Slotted brakes (Grimm)
i doubt you'd go that fast to need slotted.. it's rare that any street car would.. but i got htem on my car.. i jsut like the way they look ;p
UnoPuntoCinco
05-30-2007 04:23 PM
