B16a2 Compression Ratio?
B16a2 Compression Test? What's condsidered good?
What's is the B16a2 compression test suppose to be? Do these compression levels change on how much power/compression ratio that each cylinder puts out? Or is it the same for all B16a-B18c5???
[Modified by SloEG, 8:31 AM 7/28/2002]
1021, 99, b16a2, check, comoression, compression, cylinder, powercompression, rate, ratio, specs, test
