Lower control arm/steering knuckle balljoint
Hello, this is my first post. I am having trouble seperating the lower control arm from the steering knuckle on the driver's side. I am using a puller (with nut still on balljoint) but it is not working. I am afraid to try more force fearing that I might damage the balljoint. I have sucessfully seperated the passenger side already. If someone have any ideas or suggestions that might help it will be appreciated.
Re: Lower control arm/steering knuckle balljoint (kouisan)
There is a little nub on the lower control arm that you're supposed to hit with a hammer. If you keep hitting it in that spot, it will seperate the balljoint. You can also use a ball joint seperator tool if you have one. Otherwise, hammering the lower control arm will work.
Re: Lower control arm/steering knuckle balljoint (EG9turbo)
Hit it with a 5lb sledge to knock it loose. Hit is hard, about 5 times. Jack up on the spindle a little so the LCA has pressure down from the sway bar.
Re: Lower control arm/steering knuckle balljoint (acura_typer)
I put the lug wrench (that came from the dealer) between the LCA and the knucle, and hit it with a big brick. The brick broke in two, the lug wrench bent, and, Voila, the joint was separated. (No kidding, true story)
Try it, it works!
Try it, it works!
Shawn
r_kage
08-30-2016 01:35 PM
Pushhands
Honda Civic (2006 - 2015)
05-12-2014 06:59 AM
DougieStyle
Suspension & Brakes
07-12-2006 11:07 PM
