Nagging Problem
Old Jul 26, 2002 | 06:50 PM
skywlkr235's Avatar
Default Nagging Problem
The other day, I was driving my car and noticed that fan speeds 1 and 2 are not functioning. 3 & 4 operate as normal, but on 1 & 2 there is no air blowing out of any vents. It does not matter if it is set on defrost, face, feet, both, etc. Could it be a bad contact, or maybe a bad fan motor?
I checked into the problem further with the car parked without the engine running. When I move the fan speed switch to 1 or 2 I hear a fan/electric motor start humming (coming from somewhere in the engine. However the fan inside the car (inside the firewall) does not turn on until speeds 3 & 4. I unplugged and then reseated the electric plug that plugs directly into the inside fan motor but that didn't remedy the problem.
Any Ideas?
Thanks,
Luke
lukelehman@hotmail.com
Old Jul 26, 2002 | 06:55 PM
markpaco's Avatar
Default Re: Nagging Problem (skywlkr235)
it is likely the blower resistor. It is behind the glove compartment and has a plug going into it. Take it out and inspect it. There are 4 coiled wires. make sure they are still intact. Otherwise, you will need a new one or you might be able to twist them back together or solder them. If not, go to a wrecking yard and get a new one. Should only be like $0-$5.
Bender C/F
Feb 12, 2010 07:46 PM
phelpsj2
Jul 24, 2009 08:17 AM
bcaslow
Mar 18, 2008 01:10 PM
jth8448
Feb 5, 2008 09:55 PM
b16_madman
Nov 15, 2003 04:59 PM
