Camber kits??
Old 07-29-2002, 05:27 AM
Takeoff's Avatar
Default Camber kits??
What camber kits are you all using? Is the Skunk2 kit good? Do I need rear camber kit or is stock fully adjustable for a 1.5"-2 drop? Does anyone have camber plates on their coilovers? Thanks.
Old 07-29-2002, 07:23 AM
EEK
EEK's Avatar
Default Re: Camber kits?? (Takeoff)
I got a sprint camber kit,, I didnt need ones in the back but with 1.5-2inch drop i dont think you gonna have that much of a camber problem
Old 07-29-2002, 07:31 AM
migs's Avatar
Very. Easy to adjust and I find them reliable.
I had the alignment shop adjust my camber back to 0 without using my Ingalls camber kit. They said stock adjustments was sufficient.
If you are referring to EG/EK/DC chassis, you cannot utilize camber plates on top of shocks because we have wishbone suspension of front. If you look at the geometry of the front shock, you notice the camber will not be affected at the angle of the shock regardless of much you play with it. Camber plates are found on McPherson strut type vehicles, i.e. 240's, BMW's, RSX
Hope this helps.
Old 07-29-2002, 08:32 AM
turboman's Avatar
Default Re: Camber kits?? (MiGs)
That looks really nice. I'm using Ingalis myself. It does what I want so no point in spending more money. I wouldn't get it again because I've seen nicer setups and I really only got it for racing and it doesn't adjust very much.
Old 07-29-2002, 08:57 AM
Takeoff's Avatar
Default Re: Camber kits?? (turboman)
Thank you MiGs. Answered all my questions.
Old 07-29-2002, 09:11 AM
cre18's Avatar
skunk2 front camber kit and specailty rear. both are very easy to install and adjust.
Old 07-29-2002, 09:37 PM
HBack94cx's Avatar
so can i get my stock rear cambers adjusted without having to buy any parts, my car is lowered 1.5 in the back and the tires are wearing on the inside
Old 07-29-2002, 10:54 PM
sherman's Avatar
Default Re: Camber kits?? (HBack94cx)
Washers can be used in the back to fix your camber problems.
Old 07-29-2002, 11:41 PM
tFUnK's Avatar
i thought the stock rear was a negative 1 degree camber from factory? either way, I've been riding on itr springs with about an inch drop and now on ctr springs with a little more drop than itr, and my rear tires do not have uneven tread wear. my front tires are a different story though
[Modified by tFUnK, 12:41 AM 7/30/2002]
Old 07-30-2002, 04:01 AM
gavhowe's Avatar
Default Re: Camber kits?? (sherman)
How think do u need to space out with 2 inch drop
mattdenali
Suspension & Brakes
05-26-2005 09:21 PM
fafsa
04-06-2005 03:41 PM
pcorad
12-01-2002 06:18 PM
01 ITR 757
04-01-2002 07:15 PM
Wai
01-02-2002 09:08 AM
Quick Reply: Camber kits??
