cant find D16zg swap so...
Okay my 92CX motor is smoking cause the rings are gone...So ive been looking for a D16z6 swap..and i havent had any kinda luck.. So i found a 93 DX 4door here locally..its got a D15b7 ...Will this work in my 92cx ...Any differences in wiring?? engine mounts???? and will my CX tranny still work with the D15b7?? Are these engines better than the CX as far as reliability..and strength?? will my CX A/C still work on the D15b7 which compressor will i need?? DO i also need to get the DX ecu?? what all will i need from the DX to make it all work...(a list would be nice) ...Thanks
Re: cant find D16zg swap so... (SLowCrx)
same wiring, no other wiring necessary, i believe u'll need the ecu from the dx, yes the tranny will work, but high redline u might have problems shifting with the gear ratios of the CX tranny. strengh wise it's 102 hp i believe rather than ur whopping 92 hp that can't open a pickle jar
a/c will also work, no mods required, they all use the same compressor for EG a/c's, for EK's there is lil modification but nothing major -- but that doesn't apply so, but
this will be a VERY easy swap for you. plug and play, tighten bolts and time is all it'll cost you
hth
hth
cx 70hp
vx 92hp
yea go for it...it should drop rite in...anything is better than a cx...or u could do mini-me. and add a ex tranny...ull notice such a difference!
vx 92hp
Re: cant find D16zg swap so... (dniedacess)
cx 70hp
vx 92hp
vx 92hp
good luck on ur swap man
Re: cant find D16zg swap so... (poison)
Ok so all I need is the engine and wiring harness and ecu everything else i can get from my CX right...?Are you sure the CX ecu wont work with the DX engine...ive been told it will...?? Thanks
Re: cant find D16zg swap so... (Downeybear11)
Are the engine mount the same on a d15b7 and d15b8...Meaning can i take off my CX mounts and use them on the DX engine?? Is the gear ratios in the CX tranny much Different from the DX?? Will my CX ecu work on the DX engine?? Thanks...
Re: cant find D16zg swap so... (In The 16s)
Is my CX alternator still gonna work on the DX or am i gonna have to change brackets?? Is the DX tranny much different than the CX tranny?thanks..
hey i have a d16z6 Sohc vtec swap. MAybe for the right price i will sell it I am looking to get rid of it so email me and let me know. I also need to know where you live I am from NJ so. Let me know
SDT Project EF
51
01-31-2005 12:09 AM
SLOAZZ95
10
11-18-2004 03:13 PM
