sohc to sohc vtec HELP!!!!
So, I just put in my d16z6 into my sol S and now it won't even turn over. WTF did I do wrong? D16z6, p28 ecu. Fuel pump doesn't come on, and it won't even try to turn over... HELP!!!!
Re: sohc to sohc vtec HELP!!!! (Bakeoff)
did you remember to hook up the grounds on the engine. Ive heard that the d16 is really picky about having the grounds correct.
Need to do some checks first, is there spark, second is there fuel pressure, is there fuel firing, cause one could be a bad ground, the spark plugs would not fire
Re: sohc to sohc vtec HELP!!!! (twitchm80)
I know I didn't hook up the ground on the tranny. The cable was too short, so I was going to replace it today. But that doesn't explain why the fuel pump didn't come on.
I redid all the grounds. The dash lights come on brighter now, and the fuel pump comes on. Still not cranking though...
hondaracing1
12-24-2003 09:56 PM
EG2 SiR
08-19-2003 10:14 AM
