Questions about milling my head...
I have the capabilities to shave my head myself, the only problem is how much do I need to take off? I have a 1stGen JDM B16a (equal to a U.S. B16a3) which has a 10.2 compression ratio stock, I'm looking to make it no more than 11.1 CR (JDM B18C 96 spec.R). In order to achieve this, how many thousandths do I need to remove? Will I need to run high compression pistons if I go this route, or should I play it safe and mill it to 10.8 CR (JDM B16B 98 spec.R)?
Any information will be greatly appreciated.
Peace
Peace
Re: Questions about milling my head... (iLLestjr)
I don't have any high compressoon pistons at this time. It would be easier and cheaper to mill the head instead. I just need to know how much is usually taken off. Thanks for any help.
peace
[Modified by Enlightened, 6:47 PM 8/9/2002]
peace
Re: Questions about milling my head... (Enlightened)
I don't have any high compression pistons at this time. It would be easier and cheaper to mill the head instead
Re: Questions about milling my head... (Doctor CorteZ)
just get some jdm itr pistond for 200 bux on ebay. OEM quality, along with the high-compression you wanted.
Are you new to milling heads, did someone just show you how to do it?
Get the pistons.
Get the pistons.
baam
11-15-2005 08:58 AM
gsr98vtec
01-04-2002 05:25 PM
