is this the evap purge valve?
is this the evap purge valve? *pic inside* help
is this the evaporating purge valve for a gsr? if not, where is it???
[Modified by lilxvtecxpwr, 1:22 PM 8/9/2002]
[Modified by lilxvtecxpwr, 1:24 PM 8/9/2002]
Re: is this the evap purge valve? *pic inside* help (Jackson)
also can someone post the wiring on that the purge valve. when i got my swap in the wires the red and yellow/black was cut but didnt get a check engine light. soo now i just need to know where that red wire goes and the yellow/black wire goes. thanks
Carlo
Carlo
Re: is this the evap purge valve? *pic inside* help (ChampwhiteSi)
your car will run fine without it. if you are really concerned about the enviroment... then connect the yel/blk line to any 12v hot-when-on source (i.e. any yel/black wire) and connect the other line to A20.
raidacaipo
05-12-2008 08:07 PM
Dc4iNtEgRa
04-17-2008 10:55 AM
the soL that could
03-31-2006 12:57 PM
LuderX
01-13-2003 05:49 PM
