96 gsr brake system to 98 hatch?
hey all, i was just down at the shop, and my buddy knows this guy that has a 96 gsr shell and it has the whole braking system on it, what do i need from the gsr, to put the disks all around on my hatch, please list all of the parts, as he said he would do everything for 350.00 canadian, any reply much appreciated thanks
Re: 96 gsr brake system to 98 hatch? (98silverhatch)
Lessee:
1. Front & rear brake assemblies
2. Front steering knuckles with hubs and brake rotors
3. Brake master cylinder & booster
4. Crazy mojo to custom bend brake lines to fit GSR master cylinder
(Use Integra RS 15/16th's master and booster to fit properly without rebending)
5. Proportioning valve
6. Rear brake lines
7. Rear trailing arms and front compensator arm and upper control arm
8. Rear rotors
8. All caliper mounting hardware
9. Parking brake cables (the GSR's will work, but you're better off with the Civic SI ones)
10. New pads
11. Machining of old rotors if they're rusted beyond recognition, or even new ones
12. Several hours of time to help out your buddy, because it's worth more than 350.00 in labor .... so if you want you buddy to stay your buddy....
Shawn
6. Rear brake lines
8. Rear rotors
10. New pads
Shawn
Romo Pyro
Suspension & Brakes
12
02-18-2014 08:32 AM
