Koni Yellow Interchangeability
Ok, I have a set of Koni Yellows that came off my 99 EK, and I am planning on using them on a 92 CX w/ GC coilovers. My question is, will these bolt right up or will there be any problems? According to Koni's site, the part numbers for the front shocks on EG's and EK's are identical - 8041-1152, but the rear shock part numbers are different: 8041-1153 for the EG and 8041-1213 for the EK. Anyone have any input on this?
Re: Koni Yellow Interchangeability (netnutshatch)
Konis for 92-95 Civics and 94-01 Integras are exactly the same all around. You will be fine.
[Modified by PatrickGSR94, 9:03 PM 9/17/2002]
Maybe I'm wrong, as I don't own a 96+ Civic, but aren't their LCAs a different length than 92-95 Civics and 94-01 Integras?
Re: Koni Yellow Interchangeability (SkyeC)
I was just wondering the same thing. I just spent a buttload of money on my koni's and now im thinkin about buying a new car. im sure if you use the right parts they'll fit.
1 Post
Re: Koni Yellow Interchangeability (PatrickGSR94)
Former Moderator
Re: Koni Yellow Interchangeability (hoya_10fintec)
I'll set it straight:
I have EK Konis on my EG/EH hatch.
The front bolt directly up with nodifferences whatsoever, BUT the rears require modification to your Civic's or Integra lower control arms.
The EK-style struts has a thinner bottom fork, so you must get a grinder or a ziz-wheel and cut some thin slices off of the lower control arms bushings where the lower strut fork slides over it.
In my case I was using Energy Sus bushings, so I simply trimmed my bushings down on a bandsaw.
That should settle it.
Suspension geometry (and thus LCA length) is the same across all 94-01 Integras and 92-00 Civics. It's just the LCA bushings.
Oops I got mixed, you have 99 Civic Koni shocks now, so yeah you'll have to trim the bushings in the GS-R LCA's to get them to fit.
99Ek_Fred
14
02-22-2017 03:32 AM
Jonovision
03-30-2008 07:14 PM
run-it-red
09-15-2005 05:43 AM
