H22A question.
H22A question.
Is it possible to do an engine swap for a H22A JDM Prelude Engine in my 97 Civic? If so, how much more trouble would it be than just putting in a B16 or B18 Civic/Integra engine?
Re: H22A question. (xthisfallx)
It is a lot more trouble. It isn't a direct swap. There is quite a bit rewiring required.
http://www.placeracing.com has a direct bolt in kit for the engine mounts. But there site is under construction. I believe the mounts are around 600+.
You cannot use the Prelude axles. You have to use a mix of them.
Not the easiest thing but, certainly a very fun engine once installed
properly.
Sport Compact Car did an article on this. It is in the September 2001 issue.
properly.
Re: H22A question. (Spade)
i didnt find it any harder than a b- series swap, i found it to be fairly easy
just do a search there is alot of info on this site about it
Re: H22A question. (H22a-CX)
Former Moderator
Re: H22A question. (b18ccivichb)
Do I see a pattern here?
I've locked 4 or 5 H22A topics in the past 5 minutes.
I did the search in "H22A" and found 3 pages full on "Recent" topics and 5 pages on "Archived" topics.
Lock.
Lock.
