rear trailing arms: drum vs disc
i planned to do a rear disc conversion on my EH2, and I assumed that I needed rear trailing arms/hubs/calipers/cables/etc from a donor car.
well, now i've heard that all I'll need is the rear caliper brackets/calipers/cables (not hub/trailing arm) because once i remove the old drums, everything bolts directly to the drum trailing arms. which would mean that the rear drum trailing arms are the same as the rear disc trailing arms.
is this true?
is this true?
Re: rear trailing arms: drum vs disc (DOHC-DX)
yes,you are correct,there are 4(i think) hex head bolts that holds the hub and the rear drums assymbly,if you jack the car up and look on the inside you can see them,you just unbolt those 4 bolts and the whole thing comes off,then the new discs will go up the same way,its way easier then replacing the whole arm.you will need the complete hub,disc,caliper and ebrake cables,the cables will not reach completely,they are a tad short on one side i think,but its no biggy,just use a few zip ties to keep it up in place.
[Modified by civictypenos, 2:20 PM 9/17/2002]
See told ya. You need (Hub,Calipers,e brake cables, and get brand new fresh whatever you want rotors and pads). I think that is the list. The hubs you will need yes they are what make the swap happen. Oh and some
holy crap! best thread ever! i've been hittin up salvage yards for a month now lookin for gsr trailing arms and stuff to swap out my rear drums. do i seriously only need to grab the hubs and ebrake cables if im gettin aftermarket big brakes? to the person who posted this
Re: rear trailing arms: drum vs disc (civictypenos)
The trailing arm assembly from drums to discs ARE different. They have different brake line mounting points. Additionally, you need different brake lines for the rear calipers - they are dramatically different.
To do it right, you have to buy so many parts that you're just better off buying a junked trailing arm with all the parts already attatched, and put together in a convenient package.
That's why everybody else does it that way. It's cheaper and easier to do it right by getting the trailing arm.
Shawn
Re: rear trailing arms: drum vs disc (shawnhayes)
i can get new e-brake cables for $40, and i knew the flex lines are different... that goes w/o saying.
i don't want the trailing arms because:
they're heavy, and shipping is expensive
by replacing the trailing arms, i have to get an alignment done.
Shawn
i have to say i disagree,it was much easier(ive done them both ways)to do just the hub,4 bolts,and off with the old and 4 bolts on with the new,i did not need an alignment when i got done,i dont understand why you would,if your tires where staight to start with why would they be off if you dont touch the adjustments.i did forget about the brake lines,yes you do need those,as far as using zip ties,i think i had to use 2 of them,the other 4 or 5 bolts lined up ok,so its not a big deal,your e brake cables are held up by alot of gas tank guards and heat sheilds under the car,its not like it going to fall off,i think the reason why people use the whole assymbly is just because they think they have too,if it where me and i was buying them from someone out of state,save your money and just get the hubs shipped,i bought claipers from a 90-93 integra for mine from a salvage yard and they bolt up fine,i spent $105 on my rear swap,that included shipping,new pads and everything,minus my ss brake lines.so,new revised list of parts you MUST have:
rear hubs
integra e brake cables
discs
calipers from 90-up integra or civic with discs
rear brake lines
the trailing arms are optional
brake pads and fluid
rear hubs
discs
rear brake lines
Shawn
One half a millimeter or so difference in the mounting at hub mounting point can change the alignment
wade
Suspension & Brakes
05-25-2006 12:18 PM
soundbomber
20
01-20-2004 02:29 PM
