Anyone with EGs have 15s? What size tires do you have?
I have a EG with the 00 Si Rims and H & R Sport springs. I got some Kumho Ecstas in 195/55/15 because that was the size of the stock Michelin tires. It turns out they rub a lot on the plastic part on the inside of my fenders when i take semi fast turns(bugs the hell out of me). I'm sure 45s will be fine but if I get 50s will they still rub? What tires do you suggest?
[Modified by Maverick77, 9:16 PM 9/15/2002]
Re: Anyone with EGs have 15s? What size tires do you have? (Maverick77)
don't get the 45s go with the 195/50/15 tires. That's what i run on my car, next tire change i'm going to 205/50/15 tires.
Guest
Posts: n/a
195/50-15 maintains a rolling diameter that's close to stock. This means your speedometer shoudn't be that off, and if you have ABS, your car won't prematurely lock up, especially in the wet.
Also, 205/50-15 has a rolling diameter close to 195/55-15 that they're practically the same. If you rub with 195/55, you'll rub with 205/50.
[Modified by VTEC, 5:22 AM 9/16/2002]
I have neuspeed race springs and neuspeed koni yellows and no my tires never rub.
Here is my car. As you can see it's fairly low and no rubbing with these tires. My Wheel offset is 45.
Re: Anyone with EGs have 15s? What size tires do you have? (mantic6t9)
New User
Re: Anyone with EGs have 15s? What size tires do you have? (VTEC)
I have some '00 Si wheels also with the stock 195/55 michelins on them.
If I were to switch to a 195/50 tire later when I need new tires, then that will make them smaller in diameter right? Wouldn't this put more miles on your car and more wear? Or is the difference not that big of a difference?
Thanks for input
Thanks for input
Re: Anyone with EGs have 15s? What size tires do you have? (feint_style)
i have 195/55/15 and have never had a problem. my car isn't that low i guess. my new tires are 50s but that jusy because 55s weren't an option on yoko AVS ES100
