honda civic radio removal - 6g
Old 02-24-2003, 07:16 PM
tominos's Avatar
Default honda civic radio removal - 6g
do you guys know the site where it has instructions on how to install a deck into a civic, i don't know how to remove my deck. its a 97 civic. thanks
Old 02-24-2003, 07:25 PM
poison's Avatar
Default Re: honda civic radio removal - 6g (tominos)
here's the pin-outs and colors to the stock wiring
http://www.jdmfan.com/index.php?info...=radio_pinouts
Old 02-24-2003, 07:28 PM
tominos's Avatar
Default Re: honda civic radio removal - 6g (poison)
thanks good info, now i need to know how to remove the deck. if i take the panels off, where are the screws that hold the deck in place?
Old 02-24-2003, 07:31 PM
B16b2b's Avatar
the stereo ( top portion with tuner) is fastened to a bracket the runs across the dash behind the big a/c stereo portion of trim...if i remember correctly, there is a bracket that is screwed onto the back of the stereo, makes a 90degree bend and is screwed onto the afformentioned barcket. to get to it you'll need to first reomve all of the lower dash pieces (3 of them).
**** if you lay on your back and look up at the bttom backside of the radio, you'll see the screw(s)...can't remember how may there are, not more than three.****
[Modified by B16b2b, 11:34 PM 2/24/2003]
Old 02-24-2003, 07:32 PM
freakin_eLRoD's Avatar
the stock deck is held by screws from the rear of the deck. you'll have to remove that lower panel where the power outlet is at to gain access to those screws.
Old 02-24-2003, 07:34 PM
tominos's Avatar
Default Re: honda civic radio removal - 6g (B16b2b)
is it screws or bolts? so remove all three panels, ie. glove box, cigareete lighter panel, and steering column panel right? then i should be able to see it correct?
edit: i looked at it a couple months ago and couldn't figure it out, so had the deck installed by car stereo city(free installation), now it's time to change decks.
[Modified by tominos, 8:37 PM 2/24/2003]
Old 02-24-2003, 07:38 PM
B16b2b's Avatar
[Modified by tominos, 8:35 PM 2/24/2003]
i think you need to remove the leftside panel completely, but you can bend your glove box over the stop, so you don't have to remove it ( pass. side panel). but the screws to the middle piece are hidden by the glove box, and the driver side panel. take off the center piece, and they'll be screws. phillips.
Old 02-24-2003, 07:46 PM
tominos's Avatar
coo thanks.
BlackHXCoupe
Audio / Security / Video
06-14-2006 11:41 AM
D50boy
04-03-2005 01:23 PM
Deerslayer
09-15-2004 06:50 PM
projectcrx
06-21-2003 01:20 AM
gkirby
04-30-2002 09:54 PM
Quick Reply: honda civic radio removal - 6g
