skunk2 camber kit questions...
well my camber kit came in today, but i had a question.
it has no directions, and their webpage has no downloads. i know how to replace the A-Arm but it doesnt inform me on the proper way of adjusting the kit to Zero out my camber. anyone have any information?
thanks
thanks
Re: skunk2 camber kit questions... (haloseven)
trial and error bro, it may take a few times but you will get it... i put the balljoint as far out as a could first, then gradually backed off untill it was good. and make you sure you get some serious leverage on that alen head b/c you dont want the balljoint sliding on you when youre driving... tighten it up real well.
thanks
thanks
Re: skunk2 camber kit questions... (Takeoff)
First thing is to throw the allen head bolts in the garbage and get some stainless steel bolts to replace them with. The allen head strip very easy.
If you haven't changed the height of your car and you know your camber is fine just place the ball joint in the same place as your stock upper arm. This should put it in exactly the same place as you have it. If you have it dropped take it to someone for an alignment.
thanks for the info so far
jdmeg6honda
Suspension & Brakes
04-16-2011 10:25 AM
