My timing belt broke after only 5,000 miles?
Old 05-01-2004, 04:13 PM
Go-Cart's Avatar
Default My timing belt broke after only 5,000 miles?
Had a new belt installed by mechanic. Was going 60 then, snap.
What might be the cause the failure of a new belt. I also changed the water pump when I had the new belt installed. Also, how likely is valve damage when a D16 snaps its belt?
Old 05-01-2004, 04:15 PM
Luserkid's Avatar
Default Re: My timing belt broke after only 5,000 miles? (Go-Cart)
Was the belt exposed? Maybe a rock jumped up and got in there.
Or maybe it was just a cheap belt, i would go back to that mechanic and bitch to him to fix it.
Old 05-01-2004, 04:16 PM
Go-Cart's Avatar
Default Re: My timing belt broke after only 5,000 miles? (Luserkid)
No, the stock cover is properly installed.
Old 05-01-2004, 04:18 PM
RCautoworks's Avatar
Bad luck or bad install
Old 05-01-2004, 04:21 PM
Go-Cart's Avatar
If it was installed properly then its not his fault. To make sure its done right this time though I have my car in the good hands at Intercrew. They are going to test the head to see if I bent any valves.
Anyone have experience with a timing belt breaking on a D16.
Old 05-01-2004, 04:36 PM
ABK
ABK's Avatar
could be over tightened
Old 05-01-2004, 06:22 PM
Go-Cart's Avatar
ttt
Old 05-01-2004, 06:24 PM
ABK
ABK's Avatar
I don't think it would **** anything up, just go to the mechanic and get your money back, and do it yourself or pay some one to do it that know what they are doing. BTW new timing belt is like $30 I think.
Old 05-01-2004, 06:25 PM
rxse7n
Guest
Posts: n/a
Possible dumb question...is it bad to not have the belt cover on there? I never really thought about a rock gettin in the way or something...horror stories?
Old 05-01-2004, 06:27 PM
ABK
ABK's Avatar
Default Re: (rxse7n)
I don't know, but one of my dumb *** friends was cleaning off the valve cover with a rag while the belt was exposed and the car was running. You could imagine what happened next. Rag cought caught timing jumped and his fingers almost got grinded to the bone.
Just put it on incase something spill on it or something hits it.
Old 05-01-2004, 06:44 PM
miahmouse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rxse7n &raquo;</TD></TR><TR><TD CLASS="quote">Possible dumb question...is it bad to not have the belt cover on there? I never really thought about a rock gettin in the way or something...horror stories?</TD></TR></TABLE>
(heavy sarcasm)yeah, those crazy bastards at honda always putting extra covers on things. Seen someone lose a screw into there, result was a timing belt hanging on by a thread.
if you still have the belt, tell us what it looked like..... straight snap? worn on the edges? etc.....
Old 05-01-2004, 06:56 PM
mingbling's Avatar
I live in Richardson, and this semester is about to end, so i wil lhave some extra time.
Modified by mingbling at 12:38 PM 5/2/2004
Modified by mingbling at 7:32 PM 5/5/2004
Old 05-01-2004, 06:57 PM
Wildcatt88's Avatar
Funny the warnings they put on things... "Do not install fan belt with engine running."
Good luck, I hope nothing was damaged!
Old 05-01-2004, 07:10 PM
EL Vap133's Avatar
Ouch! Good luck!
Old 05-01-2004, 07:14 PM
OG triple OG
ATS*Mark's Avatar
Default Re: My timing belt broke after only 5,000 miles? (EL Vap133)
was the belt oem???
im gonna bet 100 dollars it wasnt installed right , or oem . a belt is supposed to last 100k , but be changed what , every 60k?
there is no way a properly installed belt would break after 5k.
did it actually break or slip off?
Old 05-01-2004, 07:24 PM
Global Moderator
Jimmy's Avatar
Did you or did you not have your timing belt cover on?
Old 05-02-2004, 01:25 AM
atermizi's Avatar
Default Re: (Usdmdc2)
oucchhh man..timing belt break..that's a good excuse for a swap..
Old 05-02-2004, 04:50 AM
jlh81's Avatar
Default Re: (atermizi)
When i had the D16 motor in my car i broke the timing around 65000 miles and i didn't bend any valves
o i was going about 45 mph
So i think you will be ok
Old 05-02-2004, 06:59 AM
Global Moderator
Jimmy's Avatar
Another possibility could be it rubbed the teeth on the cam gear and just got a few cracks in it and eventually just broke.
Also debris i'm sure could **** your timing belt up and yet again thats another reason why i leave my timing belt cover<u>s</u> on.
Old 05-02-2004, 07:08 AM
JDM PRO's Avatar
mechanic is responsible and i would also ask if he used genuine honda parts
Old 05-02-2004, 10:59 AM
Go-Cart's Avatar
My cover was on. Any other reasons why the belt broke? What could be damaged?
Old 05-02-2004, 12:15 PM
jlh81's Avatar
Default Re: (Go-Cart)
I would say you just got a defective belt and as for any thing being wrong with you motor the answer is NO my belt broke and everything was fine when I put the my new belt on
Old 05-02-2004, 12:44 PM
4DRPIMPIN's Avatar
Default Re: My timing belt broke after only 5,000 miles? (JDM PRO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM PRO &raquo;</TD></TR><TR><TD CLASS="quote">mechanic is responsible and i would also ask if he used genuine honda parts</TD></TR></TABLE>
I have a feeling it wasn't a OEM honda Belt.
Old 05-02-2004, 01:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Go-Cart &raquo;</TD></TR><TR><TD CLASS="quote">My cover was on. Any other reasons why the belt broke? What could be damaged?</TD></TR></TABLE>
Bent valve, damaged pistons. Either you had bad luck and the belt just snapped, maybe it was a defective belt, or the mechanic did not install it properly. I would put my money on the mechanic not installing it correctly.
Old 05-02-2004, 01:17 PM
thenick's Avatar
Default Re: (90blackcrx)
did he replace the timing belt tensioner? did he adjust it properly? take your car to honda, give him the estimate to fix the motor/valvetrain.
if people can sue (innocent at that) doctors for people dying then you can sure as **** have him pay for your dead motor
Quick Reply: My timing belt broke after only 5,000 miles?
