B18C1 swap into EG
B18C1 swap into EG
i would like to get a lil help on this...my younger brother just bought a 94 jdm gsr with p72, obd1....and wants to put it into a 92-95 hatch...he has a few questions that he would like you guys to answer or help him....
1. What motor mounts (OEM) does he need to use, like off what car, to swap it into the hatch??
2. What shift linkage, off what car, would he need to swap into the hatch??
3. What wire harness to use for the swap??
4. How to hook up the knock sensor??
5. How to hook up the VTEC sensor??
Thanks in advance if you guys can help me out...
Re: B18C1 swap into EG (kcjohnnyboy)
he needs the driver's side integra mount
obd1 gsr wiring harness. i have one for sale. complete harness uncut...100 shipped. let me know.
get a gsr shift linkage of an integra
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kcjohnnyboy »</TD></TR><TR><TD CLASS="quote">
Stock mounts, i havent had a problem.
The one that comes with the swap (GSR linkage), goes right in
Depends on the hatch, if its DX then GSR, if its like a SI or one wired for VTEC (dont know which right off the top of my head) you could use there harness.
http://faq.ef-honda.com/index....ng=en
See link above.
Thanks in advance if you guys can help me out... </TD></TR></TABLE>
Good luck and have fun
See link above.
Also, what throttle cable for the swap? And, if he can use del sol vtec shift linkage instead of the gsr one?? thanks guys...
my brother has another question...and he wants to know what axles to use? the ones off the civic or the one for the swap??
you have to use the axles off the b series swap. you pretty much can't use any parts from the d series motor with the b series. all the main parts need to be b series parts. get everything from an integra to do the swap. everything you take out from your stock motor, replace it with integra motor parts.
integra:
motor
tranny
axles
harness
ecu
shift linkage
motor mount
i have the obd1 gsr harness and the driver's side mount for sale if you need them. pm me if you want them.
integra:
motor
tranny
axles
harness
ecu
shift linkage
motor mount
Mad-Mike
06-03-2011 08:53 PM
civic201
01-17-2007 03:02 PM
Ignitecivic
08-19-2004 07:12 PM
