Engine Whine at low rpm
93 Delsol Si with LS/VTec turbo it is making a funny whine at low rpm no power steering or ac and i took the alt belt off thinking it might be that any other ideas it does seem to be coming from the timing belt side
Timing belt?
Water pump?
Oil pump?
Tensioner?
Cams?
Any Help would be great
Thanks
Already searched
Timing belt?
Water pump?
Oil pump?
Tensioner?
Cams?
Thanks
Already searched
Re: Engine Whine at low rpm (tilt)
check pully bearings. they sometimes go bad. also the harmonic balancer can go bad too. but definatly check if it is coming from the timing belt. could be something loose or worn out.
Cspeclude
02-04-2003 03:05 PM
