gap between headlights and bumper
I recently put on a cold air intake on my em1, which involves removing my bumper. When I put everything back in place there is a slight gap betweent the headlight and bumper. Also, when I first bought the car there was a gap where the bumper met the fender but it wasn't that bad, now it's the same but the bumper sags a bit and there is a gap between the headlight too. Should I take apart the bumper and put it back together again in hopes that I didn't align it right? What else can I do?
thanks
sorry for the rambling. it's 1:30 am
thanks
Re: gap between headlights and bumper (Lil Corb)
Might as well take it off and try to put it back on. They don't always fit perfectly after you take them off and put them back on. Your bumper is OEM, right?
Re: gap between headlights and bumper (Brandon EM1)
its probably the support for the bumper right under the headlights those arn't lined up pull it off put the middle section on first and make sure those things are lined up on the bumper and it should be fine. If you need further help and ur in NOVA i can meet you somewhere over the weekend and help you i had that prob a few times on all my hondas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brandon EM1 »</TD></TR><TR><TD CLASS="quote">Might as well take it off and try to put it back on. They don't always fit perfectly after you take them off and put them back on. Your bumper is OEM, right?</TD></TR></TABLE>
yea it's oem
yea it's oem
