Transmission Selection. D-Series Transmission gearing. Which is best for acceleration.
Alright I have a 97 civic DX Hatch. I'm going to do a lot of motor work and stuff and I want to change the transmission. I know the DX transmission has real long gears and I wanted something that would be a better for acceleration. What D-series transmissions would be the best for acceleration. I was thinking of getting one from a 00 civic ex coupe. Any other suggestions or pro's and con's of each transmission. Thanks for the help it is greatly appreciated.
Re: Transmission Selection. D-Series Transmission gearing. Which is best for acceleration. (wushub
96-00 EX coupe if you want a factory transmission. Mistabone had a link in his signature to some crazy custom tranny that he built, but if you are asking this question, you probally aren't up to build your own.
EDIT: Pros for this tranny
Tightest gearing of any factory D series transmission.
Cons:
Still has long *** gears.
Cons:
ok, not trying to be a dick, but use the search button, this has been covered more than a thousand times
https://honda-tech.com/zerothread?id=651870
http://home.cinci.rr.com/mistab0ne/tranny.html
https://honda-tech.com/zerothread?id=453997
just pulled those up real quick, hope that helps
P.S. z6 has beefy aluminum forks that are prone to cracking and breaking, the y8 tranny has steel forks, but they are thin steel with no structural support so the bend, i know, ive bent some, but never broke em.
use the serch this same question has been posted many times yes the y8 would be the best ratio of all d series same as z6 with slight difference on final ratio but its the same (y8 newer)
i just rebuilt my ex tranny cuz i had the input shaft bearing go out on me. so i got an lx tranny to throw in so i could still drive. after having an ex tranny and go ing to the lx i hated it. first gear went to like 45 and second all the way out to 70. the 4th-5th were about the same, but it was slow as ***** to get there.
nowi swapped and have a b16 trans on my b20 but im gonna have to do something about that 5th
Casp3r88
08-25-2007 06:05 AM
PearlWhiteAccord
31
06-20-2004 03:40 PM
bryfug13
01-14-2004 12:05 PM
acceleratin, accelerating, acceleration, building, d16, del, dseries, gearing, gears, honda, long, series, sol, tranny, trans, transmis, transmission
