ECU Qustion ? 93 dx civic and want to do a ls swap..
i have a 93 DX civic hatch and em looking to get a 99ls obd2 swap. What ecu should i go with? and i plan on going turbo. 1) should i use my dx ecu and get it chippet to ls specs.? 2) should i get a 92 to 95 ls obd1 ecu? 3)p28 rechipped will it work even thow i have no VTEC will it be easyer one to use for this swap bec i herd u dont need to wire up knok off sensors? dont realy get get it just herd it. 4) bec im going turbo does this mean i should use some thing diffent? thanks for your time!!!!
Mr. Badwrench
Re: ECU Qustion ? 93 dx civic and want to do a ls swap.. (ted)
get an obd1 ls dizzy and injectors, and you may need an altermator unless you know how to repin it, and use the dx harness, with a 94-5 ls ecu you will be fine.
Re: ECU Qustion ? 93 dx civic and want to do a ls swap.. (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">get an obd1 ls dizzy and injectors, and you may need an altermator unless you know how to repin it, and use the dx harness, with a 94-5 ls ecu you will be fine.</TD></TR></TABLE>
if you get a usdm motor with a harness, you can just plug it right in to the car harness and us a obd1 p75 ecu.
ted
02-14-2005 03:30 PM
