this little thing fell out of my b16 head WHAT IS IT?!?!
Moderator
Re: this little thing fell out of my b16 head WHAT IS IT?!?! (jbell)
goes on the number 3 cam cap....between cap and head...where it feeds the oil for the cam caps...
Re: this little thing fell out of my b16 head WHAT IS IT?!?! (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">goes on the number 3 cam cap....between cap and head...where it feeds the oil for the cam caps...</TD></TR></TABLE>
What he said
What he said
Moderator
Re: this little thing fell out of my b16 head WHAT IS IT?!?! (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua »</TD></TR><TR><TD CLASS="quote">guide pin or dowel pin for lining up the gasket, head to block. </TD></TR></TABLE>
wrong try again....
wrong try again....
you sir are correct.
wrong try again....</TD></TR></TABLE>
No I think he is right, there were two on the b18 I was working on.
Location: hittin corners so hard you can taste my rims..
Re: this little thing fell out of my b16 head WHAT IS IT?!?! (saywhat)
thats a shitty pic.. is it hollow? ide say either a dowel pin, or could... depending on how small it really is, could be the oil pins between each rocker arm, that engages VTEC and locks in the secondary lobe.
Re: this little thing fell out of my b16 head WHAT IS IT?!?! (Built B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saywhat »</TD></TR><TR><TD CLASS="quote">No I think he is right, there were two on the b18 I was working on.</TD></TR></TABLE>
Chad is right, if you look at the size of the dowel in the pic it is smaller than the two dowels you are referring to that are on the block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A »</TD></TR><TR><TD CLASS="quote">thats a shitty pic.. is it hollow? ide say either a dowel pin, or could... depending on how small it really is, could be the oil pins between each rocker arm, that engages VTEC and locks in the secondary lobe.</TD></TR></TABLE>
If you look closely it is hollow and small which resembles the dowels on the cam caps. Therefore it couldnt be the oil pistons that are in the rockers cause they are solid.
Solbros Owns Me
will people EVER read the responses before they psot? This is the LITTLE dowel pin, not the one for the head to block
StreetEG
78
11-27-2005 04:58 PM
