Code 91????
Old Jan 4, 2005 | 10:03 PM
ek_b16's Avatar
Default Code 91????
Ek throwing code 91 for fuel pressure.. car starts but when you give it gas it dies. idles fine at 900-1k..If you slowly increase gas then it will rev and stay but if you give it gas to fast it will die..any info would helps. lmk. thanks.
Old Jan 5, 2005 | 03:22 AM
92civicb18b1's Avatar
Default Re: Code 91???? (ek_b16)
dizzy
timing
something else in the igition sysytem
Mine does the same thing, and I know for a fact it's the distributor. I throw an electrical load detector code or something like that.
Old Jan 5, 2005 | 04:16 AM
HellbillY's Avatar
Default Re: Code 91???? (92civicb18b1)
eld is in the fuse box under the hood.
Old Jan 5, 2005 | 04:19 AM
Filthy Focker!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicb18b1 &raquo;</TD></TR><TR><TD CLASS="quote">dizzy
timing
Mine does the same thing, and I know for a fact it's the distributor. I throw an electrical load detector code or something like that.</TD></TR></TABLE>
Code 91 has nothing to do with that. In your case, someone spliced into the ignition circuit.
A code 91 are a bit annoying to diagnose. They could something as stupid as a faulty gas cap, or something a more relevant. What is happening is that the ecm has detected low voltage from the fuel tank pressure sensor.
DO this first:
reset your ecm (disconnect battery) and start car with the gas cap off and see if this happens again. If so, then you will need to start the troubleshooting procedure to find the fault. Best thing would be to get yourself a manual. If not, come back here.
fs
Old Jan 5, 2005 | 04:22 AM
HellbillY's Avatar
Default Re: Code 91???? (HellbillY)
have you also checked your fuel filter. also check your air filter. if either one of those are dirty it can cause a lean condition which will set that code. has it stumbled lately or is this just aproblem that started overnight. ususally a fuel problem will make itself noticable early on with poor milage, stuttering, rough starts, etc...
Old Jan 5, 2005 | 05:24 AM
spoonek9's Avatar
What year EK and what ECU are you using?
Old Jan 5, 2005 | 11:19 AM
Default Re: Code 91???? (spoonek9)
yea, i was the one who spliced it. Thought maybe since he had the same symptoms he should look into it.
Old Jan 5, 2005 | 06:40 PM
ek_b16's Avatar
timing
I've had that problem with the electrical load detectoron my friends 99 si.. The car would start but then the battery would die and not charge.Do you have a after market header on a ek?? If u do then its the secondary o2 wires touching on the bottom heat shields by the cat.. Thats what i found to be the problem.
Old Jan 5, 2005 | 06:46 PM
ek_b16's Avatar
We've changed everything fuel related. Car ran fine before putting in built motor. I've heard many others with the same problems after doing a y7/y8 mini me.. Currently using y8 ecu and stock dx harness wired for vtec and changed over from 3 wire to 2 wire at the ivac plug..It's in a 97 cx..Still using y7 dizzy but i dont think that would cause this problem??
Old Jan 6, 2005 | 03:25 AM
Bump for this guy
But no
It's a LS in an 93 CX.
I know what the problem is, it's the distributor without a doubt. I had the stock civic dizzy strapped down cause I wanted to make sure it ran, it also threw code 5, MAP sensor. But I got it all worked out.
Sorry I can't help with the original therad posters question, I dont mess with OBD2 vehicles and/or D series, but it's a free bump.
Old Jan 6, 2005 | 04:51 AM
spoonek9's Avatar
You are missing a sensor in the gas tank that monitors fuel pressure. The EXs have these sensors while the 96-98 DXs don't.
http://technet.ff-squad.com/code91.htm
Old Jan 6, 2005 | 07:56 PM
ek_b16's Avatar
Thanks for the Info spoonek9 .. I knew somebody had to know what was going on. will try it and keep you guys updated..
Old Jan 30, 2005 | 08:01 PM
ek_b16's Avatar
We've tried everything.. still same thing.. car starts, idles fine but dies when you give it gas.. someone gots to know... help me up here.
mugenboi
Nov 2, 2007 05:12 AM
FuNkDrSpOt
Mar 24, 2007 01:22 AM
curioso
Nov 21, 2006 06:48 AM
B16OnTop
Sep 1, 2003 08:59 PM
Mr. Vapor
Nov 19, 2002 02:03 PM
