help me take out my stock radio
98' civic lx i'm pretty sure all the radios are the same whether an lx or not.... anywayz... i bought my headunit today and i want to know how i could take out my stock radio w/o entirely nubbin it up.. nothing big.. i'll probably get laughed at
Re: help me take out my stock radio (bonZai)
there is a peice around the head unit you pry off softly with a flat head, then there will be 2 or 4 screws holding the head unit in, then you can pull it out, unplug the antenna reciever wire and the wiring harness, then plug and wire up the new wiring harness and connect the wires then reverse the process
Re: help me take out my stock radio (BoostedVW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedVW »</TD></TR><TR><TD CLASS="quote">there is a peice around the head unit you pry off softly with a flat head, then there will be 2 or 4 screws holding the head unit in, then you can pull it out, unplug the antenna reciever wire and the wiring harness, then plug and wire up the new wiring harness and connect the wires then reverse the process </TD></TR></TABLE>
Do you have keyless entry? If so if you take the radio out I believe you will lose keyless cause it runs through the radio. But anyway, you have to take the bottom part of the dash off that is under the radio bezel, should have a cigaerate lighter or 12 volt outlet in it. After you take that piece off, you have to look up in the dash, you may have to take out the climate control to get to the radio, but there should be a few bolts holding it in place, just take those out and it should slide out, then there are a couple bolts that hold the radio in place, take those off and I think the radio will slide out too.
Not 100% sure that is exactly how it goes but you should be able to see what needs to come out once you take that panel off under the dash.
Hope that helps out a little.
Is the 98 LX dash the same as the EX? If so, DONT TRY PRYING AT THE DASH PANELS. Follow these instructions:
http://www.installdr.com/Insta...3.pdf
be professional
http://www.installdr.com/Insta...3.pdf (Adobe PDF format)
jchance
Acura TL, RL & ZDX
10-16-2007 09:02 PM
