car not going into gear sometimes
whats up guys i have a 95 civic ex 5 spd and when i start the car in the moring none of the gears would go in so after a while of messin around itll go in...... then as i drive down the street and put the car into nutruel thenstop and put it back into first it wotn go in ill have to press the clutch several times then it will go in help.................
Re: car not going into gear sometimes (crableg03)
kind of sounds like the shift fork(s) are bent. Start with the easy stuff, check the fluid, how recently has it been changed? Clutch been changed lately?
Re: car not going into gear sometimes (******)
i'd check the rezzy first to see if it's full and bleed the system. a clutch on it's way out can often cause the same effects though...
check the resivor as said before then if it is low add some, make sure its not nasty looking, if it is drain your old out put in redline gear oil the it should be good. if not check your shifter etc... hopes this help
All Motor Mentor
1 Post
Do this simple test: When the car is running and you can't put it in gear, shut the car off and see if it goes into gear easily. If it does it's a clutch problem in which case some part of it has failed and you'll need to change the clutch with another new one. If it doesn't go into gear and seems the same, then it's a transmission problem like bent shift forks or other internal problems.
alright well i checked the littel canister under the hood for the fluid and it was dry so i pput brake fluid is this right a frind told me to put brake fluid
All Motor Mentor
1 Post
Yep that's right, but you will probably have to bleed the clutch now since you may have air in it. Keep an eye on the fluid level to since you probably have a leak and will need to repair/replace something (probably the master cylinder).
