fastbrakes 11" front oem kit
Alright so I have the Fastbrakes 11" front oem kit on my 94 Civic Dx which is non abs. I know that the kit uses Corrado rotors, but I need to know what kind of calipers it uses because I need new pads. I was very sure that they were 91 ex calipers but after ordering EBC green-stuff pads and finding out that they didn't fit I need help before I order another wrong part.
Thanks in advance,
Chris
Thanks in advance,
Chris
Future Texas Boy
Re: fastbrakes 11" front oem kit (Hartattack)
I know the 11.75" Front upgrade uses 4 piston Wilwood Calipers, I don't know if that's standard on all their caliper upgrades or not.
Re: fastbrakes 11" front oem kit (2000EM1)
They are not wilwoods for sure, because it states that it uses an oem caliper. I am just not sure which one. They are single piston, pretty much the same as stock but much bigger.
I have the 11" OEM FRONT brake kit on my 96 dx civic..and I was given Gsr Calipers when I purchased the system from brian at fastbrakes.. so it should either be gsr calipers good luck
The kit can be used with any Nissin caliper stating ..CL14VN <-- 14VN, most likely you'll either have the GSR calipers or the 16CL14VN calipers which come of the 5th gen Coupe D16z6/y8 (which is the? Si?)
#1 Super Guy
Re: (Dirk-EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dirk-EG »</TD></TR><TR><TD CLASS="quote">The kit can be used with any Nissin caliper stating ..CL14VN <-- 14VN, most likely you'll either have the GSR calipers or the 16CL14VN calipers which come of the 5th gen Coupe D16z6/y8 (which is the? Si?)</TD></TR></TABLE>
93-95 civic EX 2 door coupe.
Denny317
07-21-2003 11:04 AM
