swap help
swap help
since i have a 97dx motor laying around.. and my stock motor is **** because my intake suck water in there. I was wonderin' if that DX will fit on my 95 del sol. can I USED THE SAME MOUNTS and PLUGS n stuff? will it juss plug and play? since that motor is OBD2. need a little help.
Re: swap help (EG2SnailLike)
Bump for a little help. What engine did the del sol have in there to start with? I don't know too much about the del sol but if it was the b series, then it's not plug and play. Don't know about the rest.
your del sol should be a D15B7 or D16Z6 series which should allow you to drop in the D15Y7 motor and plug and play since they all are ODB2. Since they are D-Series motors the mounts you have should work.
'93-'95 CIVIC DEL SOL S SOHC 16V (102 HP) 1.5L D15B7 1493cc
'93-'95 CIVIC DEL SOL Si SOHC 16V VTEC(125 HP) 1.6L D16Z6 1590cc
'96-'99 CIVIC DX, LX w/TEC dist SOHC 16V (115 HP) 1.6L D16Y7 1590cc
gotsol607
12-23-2006 06:18 AM
Mjh787
05-09-2006 07:51 PM
