Fan isn't working?
Fan isn't working?
Ok, so it was raining pretty hard today in socal. I drove through a big puddle and all of a sudden my heater stopped working. I tried turning the fan from high to low but nothing happens. The climate light indicator? (the light that tells you what button is pressed) also goes dead. Do you guys think I blew a fuse somewhere or did the puddle short something out? Help!
Re: Fan isn't working? (jL iLLuZiOnz 9)
Any time you lose power to anything in your car the first place you should check is the fuse box unless its a light bulb. It seems as if you already suspect a fuse to be blown anyhow.
Re: Fan isn't working? (magicalfruit)
yup first thing check your fan fuses under the hood and problably under the dash then check if theres any loose wires connecting to the fan.
Re: Fan isn't working? (EJ_FaNaTiK_22)
hey thanks for the replies. turns out the fuse was blown along with others! replaced them and the car was back to normal.
hatchyksp
08-28-2010 09:25 AM
Justinleexxx
02-18-2010 12:43 PM
immajackuup
13
05-10-2008 07:34 AM
