Knock Sensor Wiring
Ok i did a search and read that the blue wire goes to the knock sensor pin on the ecu. but my question is, does the black wire go to the ecu also or is it a ground wire. and if it is a ground wire, where do you guys typically ground it?
btw this is for a y7/y8 mini me
I dont think you have the right sensor.
The knock sensor is a 1P sensor. And that plugs into the ecu. Take a pic of what your looking at. The Knock is under the manifold between cylinder 2 and 3
what if i dont? i just bought this from hatchi on HT and he said it was a knock sensor plug. That took like 10 days to get to my house. Am i just going to have to find out if it works by doing it myself?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99hatch »</TD></TR><TR><TD CLASS="quote">what if i dont? i just bought this from hatchi on HT and he said it was a knock sensor plug. That took like 10 days to get to my house. Am i just going to have to find out if it works by doing it myself?</TD></TR></TABLE>
You can use the plug you have but, make sure the wire that will come in contact w/ the pin(in the KS) is the wire you are running to the ECU. Alot of the plugs (i.e. IAT,KS,CTS, IACV etc.) have the same design.
Phil
Phil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef »</TD></TR><TR><TD CLASS="quote">You can use the plug you have but, make sure the wire that will come in contact w/ the pin(in the KS) is the wire you are running to the ECU. Alot of the plugs (i.e. IAT,KS,CTS, IACV etc.) have the same design.
Phil</TD></TR></TABLE>
does anyone know which wire would come in contact with the pin?
does anyone know which wire would come in contact with the pin?</TD></TR></TABLE>
Look at the KS. It will look like an IAT plug but, it will only have one metal prong sticking out of it. Whichever side of the plug comes into contact w/ the pin is the wire that should be ran to the ECU. It's very simple.
Phil
Phil
yea but that means putting the car back up on jacks and pullin off the oil filter and yada yada yada. there are two colors on the plug. black and blue/black, any idea which would have the prong?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99hatch »</TD></TR><TR><TD CLASS="quote">yea but that means putting the car back up on jacks and pullin off the oil filter and yada yada yada. there are two colors on the plug. black and blue/black, any idea which would have the prong?</TD></TR></TABLE>
Try them both, The one that doesn't throw a CEL is the right one. You need Trouble shooting 101
Phil
Phil
beginmyhonda
Jul 29, 2009 02:14 PM
lowpao
Nov 19, 2003 08:35 AM
