hx rims wouldnt fit on my car? wtf?!?!
i tried to put on my hx rims on my ej1 and the front wouldnt budge, they were hitting the caliper and causing the brakes to hit the rotor. the brakes are stock ex brake calipers and rotors, i thought hx's would fit? i had to buy spacers just so i can get to school tomorrow
Re: hx rims wouldnt fit on my car? wtf?!?! (93blkej1)
if you have 94-95 si/ex, they have 10.1(?) inch brakes while the other civics have 9.5, you can either run spacers, or grind your caliper about 5-8mm to have more clearance
Yes, that is correct. The Ex calipers will not clear the HX rims. This has been a known issue, sorry you had to find out the hard way. The spacers trick will work. Some people shave parts of the caliper, but if you got the spacers already, then you should be good to go. If you had an hx, lx, dx and below... then it wouldn't be an issue. NinjaSpy is correct about the size info.
Re: hx rims wouldnt fit on my car? wtf?!?! (NINJASPY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NINJASPY »</TD></TR><TR><TD CLASS="quote">if you have 94-95 si/ex, they have 10.1(?) inch brakes while the other civics have 9.5, you can either run spacers, or grind your caliper about 5-8mm to have more clearance</TD></TR></TABLE>
Not all the 94-95 EX's have those (10.1's) only the ones with ABS without ABS they have the regular 9.5.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93blkej1 »</TD></TR><TR><TD CLASS="quote">i have a 93 w/out abs</TD></TR></TABLE>
You dont count he didnt say anything about 93's hehehe
Re: hx rims wouldnt fit on my car? wtf?!?! (cnyej1)
I believe that all 92-95 EX coupes had 10" rotors upfront, non ABS ones had drums in the back instead of 4 wheel disk brakes.
Your fronts are still 10.1 regardless if you don't have ABS. If you don't have abs, you may have drums in the rear. The only 92-95 EX that had abs standard is the EX (EH9) Sedan, which had 4 wheel disc brakes. The coupes had it as an option. Some dealers back then called the Ex coupes EX-A or something.
Re: hx rims wouldnt fit on my car? wtf?!?! (Sasebonian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sasebonian »</TD></TR><TR><TD CLASS="quote">Your fronts are still 10.1 regardless if you don't have ABS. If you don't have abs, you may have drums in the rear. The only 92-95 EX that had abs standard is the EX (EH9) Sedan, which had 4 wheel disc brakes. The coupes had it as an option. Some dealers back then called the Ex coupes EX-A or something.</TD></TR></TABLE>
Nope sorry please try again my front rotors are NOT 10.1 my car isnt stored at my garage so I cant get a pic with a ruler right now but here is the info off of a autopart website. Now if the rotors were the same size as the ones with abs would they not be the same part number hell how about close to the same weight? Here I looked up 94 Non abs EX coupe front rotors and then 94 ex coupe with ABS front rotors. different part numbers and weights are way different. This would constitute a different rotor size.
NO ABS= 11.5 shipping weight http://www.partsamerica.com/Pa...Set=A
ABS= 13lb shipping weight http://www.partsamerica.com/Pa...Set=A
Re: hx rims wouldnt fit on my car? wtf?!?! (Phantastic)
are they safe to use? i bought the smallest ones they had cuz i didnt need that much clearance but the dude said they arent safe to use
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93blkej1 »</TD></TR><TR><TD CLASS="quote">are they safe to use? i bought the smallest ones they had cuz i didnt need that much clearance but the dude said they arent safe to use</TD></TR></TABLE>
Spacers are fine to use if they are on the small side... if you were to get bigger ones you would want longer wheels studs to compensate for the spacer.
Re: hx rims wouldnt fit on my car? wtf?!?! (LB562)
I had to barrow two HX rims before. They wouldnt fit the front so I put them on the rear. It was weird looking at my Del Sol with 15s in the front and 14s in the rear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnyej1 »</TD></TR><TR><TD CLASS="quote">
ABS= 13lb shipping weight http://www.partsamerica.com/Pa...Set=A </TD></TR></TABLE>
I stand corrected then.
Re: hx rims wouldnt fit on my car? wtf?!?! (Cru Jones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cru Jones »</TD></TR><TR><TD CLASS="quote">I had to barrow two HX rims before. They wouldnt fit the front so I put them on the rear. It was weird looking at my Del Sol with 15s in the front and 14s in the rear.</TD></TR></TABLE>
thats what i don't get. from 93-97 (doesn't matter what year), Del Sol Si's and VTEC's (94-97) came with stock 14" rims. why wouldn't HX's fit?
