slight hole on brake booster, right below MC
so yea.. there's a tiny small hole rite there.. I have no idea where it came from. anybody have n e idea how that came about? and is my brake booster bad?
Re: slight hole on brake booster, right below MC (mingbling96)
Did you try to hammer a nail in it and thought it might be a wrong idea so you pulled it out? Is it, was it leaking?
Re: slight hole on brake booster, right below MC (Luserkid)
i'm going to have to look closer at it. It's not leaking or anything.. i think it mite just be paint coming off..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mingbling96 »</TD></TR><TR><TD CLASS="quote">i'm going to have to look closer at it. It's not leaking or anything.. </TD></TR></TABLE>
If it's not leaking it's probably not a hole.
Re: slight hole on brake booster, right below MC (Chiovnidca)
If it IS leaking, replace it. Brake fluid sprayed all over your engine bay wont do you any favors.
how can brake fluid be leaking from the brake booster? fluid doesnt go through the booster... only through the MC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mingbling96 »</TD></TR><TR><TD CLASS="quote">how can brake fluid be leaking from the brake booster? fluid doesnt go through the booster... only through the MC</TD></TR></TABLE>
I never said anything about leaking brake fluid, this other guy did.
okae.. figured it out. Its not a hole, but a lil slight indentation rite below the MC. All brake boosters have it.. and i think it's designed to be like that so that when your MC goes bad and leaks, that the fluid will be able to leak out the bottom of the MC.
