OK Car wont start after valve adj. and fluids?
Alright Sunday I did an oil and coolant change, along with a valve adj. and the car ran fine. I waited for the fan to cut on to make sure everything was fine. The car ran beautiful. Came back later and moved car over in the garage and:
I get up this morning and now the car will not start. Battery is good (well not now after trying to crank it for 30 min. I had to call the fiance to come get me and take her back to work.)
Now that I finally got home I can check everything.
I have good fuel pressure: so main relay is out
I have good spark: so ing. and coil is out
all fuses are good.
I am stumped
What do you guys think it is?
TIA
all fuses are good.
I am stumped
TIA
Re: OK Car wont start after valve adj. and fluids? (B18C5-EH2)
well now I have checked everything and even changed out the ignitor. I also found that the screw that holds the rotor button on was all the way out and ate up the plastic cover a little bit. With that part fixed, now what?
I think I may have some fouled plugs but it is just wierd that they all of a suddon went out like that. I mean it was running fine after everything was done.
I guess I am going to try and use some older plugs I have to see if it will start tomorrow.
Re: OK Car wont start after valve adj. and fluids? (skunk2finatic)
the thing is, is that the car ran fine after everything and now it will not start.
Everything has been rechecked multiple times
Re: OK Car wont start after valve adj. and fluids? (EG-cellent)
OK, so I pulled the plugs last night and let them dry out a little until this morning. and now the car runs. I am assuming that they were flooded or something. IDK
but now the CEl stays solid the whole time when checking.
Whatcha Think?
Whatcha Think?
OK finally got a chance to work on the car a little more, Here is what is now going on.
The car runs but it idles a little high and I stillhave the CEL.
Also, I have no vtec. I did replace the dist. after I found out that the screw that holds the rotor button on worked itself out and damaged the plastic cover for the ignitor. Well now I replaced it and I still have the CEL.
THE CEL IS ALWAYS ON AND WILL NOT LET ME CHECK IT.
I have tried 3 different good working ECU's and still nothing.
Please someone help
TIA
-Cory
Please someone help
TIA
-Cory
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG-cellent »</TD></TR><TR><TD CLASS="quote">
Re: OK Car wont start after valve adj. and fluids? (slow poke)
I just purchased a new dist. from Distributor King and it did not help the problem.
I will see if I can check all the grounds again this weekend.
Thanx for the replies guys.
well I checked all of the ground and everything seems to be fine. I did however find out that one of the prongs on my chip had broken, so now that is fixed and I was able to check the CEL codes. But now that I let the car run for a minute I NOW cannot check it again. Do you guys think that I have a bad ECU or a bad Hondata S200 brain? I did notice that the red light on the inside blinks intermediately. Meaning if i tap it the light goes off. I did try another ecu and it let the cel go off which was cool. but I am still having problems.
tom48
01-30-2011 01:54 PM
RDAYA0
14
04-17-2008 03:42 PM
Khmi
07-08-2007 04:52 PM
