put in new O2 sensor but still cel
i put in a denso 4 wire wb o2 sensor and my check engine light is still on. the engine is a z6 with a p28 ecu. does it take awhile for the ecu to find the new o2 sensor or should it find it right after install.
Re: put in new O2 sensor but still cel (hondaguyexsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel »</TD></TR><TR><TD CLASS="quote">Clear the code from the ecu.
Disconnect battery or remove ecu fuse for a while to reset.
fs</TD></TR></TABLE>
I agree.
I agree.
Re: (Jimmy)
try an OEM sensor (shouln't matter) but if the code remains, it could be a different sensor, wiring to the ecu could be shot, ecu pin could be bad...
Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">
IMHO, i wouldn't of went with a denso O2 sensor.
Cheap quality and it won't be long before it breaks.
What are you talking about??
OE honda is Denso
OE honda is Denso
Re: put in new O2 sensor but still cel (sohcvtec1995)
it should detect it right off. go to autozone and see if its the same code ...you could have replaced the wrong one...take it out and put it in the other slot
Re: put in new O2 sensor but still cel (iluvboobs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvboobs »</TD></TR><TR><TD CLASS="quote">it should detect it right off. go to autozone and see if its the same code ...you could have replaced the wrong one...take it out and put it in the other slot </TD></TR></TABLE>
there is only one slot. the car is obd 1
skaternak
07-20-2008 10:50 AM
CLE
05-28-2007 10:14 AM
idontneedvtec
06-27-2004 02:13 PM
EGbeater
12-17-2003 07:02 PM
