GSR tranny problem EXPERT KNOWLEGE NEEDED (swaped into eg hatchback)
Re: GSR tranny problem EXPERT KNOWLEGE NEEDED (stickyfingers)
i swaped a jdm gsr into my girls hatchback. after it was in i started to fill the trans up with fluid and it begin to leak. No big deal a little RTV sealer will take care of that but as we started up the car i let the clucth out and it staled (in gear) so then i played with the shifter and some how found neutral. But the problem lies there ,when i was trying to find neutral i could do figure 8's with the shifter and i just could not find any gear whats so ever .... dont know how i found neutral but i did. Some body else asked me if i used the honda pin in the linkage and yes i did..some people i guess put bolts in there sometimes??????
Buut th question is has any body expierienced this or heared of this happing before? if so some input would be great!!!!!
Re: GSR tranny problem EXPERT KNOWLEGE NEEDED (roycivic92)
did that to a few times checked and re-checked (it is not the obvious it is something with the trans
i think u hvae the same problem as my d16z6 tranny. if i messed around with the tranny like shifting into every gears when the car is not moving, it sometimes end up gettin stuck or i can do figure's 8 and cant find any gear. but if i drive it normal shifting, its okay as long as i dont shift to every gear when the car is not on or not moving.
so my guess would be the synchros?
