B16a2
B16a2
I have a 99 Honda civic si with a 5th gen. motor. i blew the motor on it and I just bought a 4th gen b16a2 from japan. I want to know how do i connect the ecu to this new engine? i dont see any wires on the engine for it. Do I have to get an adaptor? If so where can i purchase one?
Re: B16a2 (KevinRad)
you do need to do a search on everything before you post but im feeling nice today
you need an obd2 to an obd1 harness
jesus tapdancing christ READ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">you need an obd2 to an obd1 harness </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">obd2 to an obd1 harness</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">harness</TD></TR></TABLE>
ok for 1 there is no such motor as a jdm b16a2, if its jdm its just B16
now for 2 you dont have to switch to obd1, its usually a better route to go but you can just use the stock ecu. you will need to put your wire harness onto the new motor. a few things may need to be added or changed but it should be easy.
It may be easier just to use your stock distributor and intake manifold
good luck
good luck
Re: B16a2 (Timmay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">ok for 1 there is no such motor as a jdm b16a2, if its jdm its just B16a</TD></TR></TABLE>
Edit for ya
Edit for ya
Former Moderator
First of all your Si should be a 6th gen to begin with, not a 5th gen. 5th gens are 92-95.
Also I really wish people would stop calling B16A2 motors JDM, and calling actual JDM "second-gen" engines "B16A2" - it gets super annoying becuse you never know what engine they actually have.
Is your engine a B16A2, or is it a JDM second-gen B16A?
Help us help you, and help yourself by knowing the correct terminology.
use your stock engine harness to wire the new engine. if something doesn't plug in, just replace that part with a part from your blown engine. THATS IT. you'll probably want to use the following parts from your blown engine: intake manifold, throttle body, altenator, injectors
Former Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KevinRad »</TD></TR><TR><TD CLASS="quote">It is a JDM 2nd gen b16</TD></TR></TABLE>
Okay if it's going into your 99-00 Civic Si, then you will need to use your engine harness and your intake manifold, injectors, distributor, and oil pump housing because it houses the OBD2 crank fluctuation sensor - the JDM engine will not have that sensor. you'll probably also want to keep your alternator, because I think the plugs are different - one is round, one is square.
Other than that it's plug and play really.
jdmbuilt
17
06-25-2003 06:16 PM
1badgsr Team X
06-06-2003 04:27 PM
