Just curious if no oil pressure sending unit affects anything...
I took my oil sending unit out to cut out the fittings to leak on the back of my block. No oil light, no CEL, but i'm reading in the "VTEC not working" threads about the oil sending unit needed for VTEC engagement. I'm running a single cam, so VTEC isn't noticeable, i'd assume it's working fine, like i said, no CEL.
Re: Just curious if no oil pressure sending unit affects anything... (O16581724 5 2 5)
im 99.999% positive all the oil pressure sending unit on the back of the block does is run to the dummy light on the dash...
Re: Just curious if no oil pressure sending unit affects anything... (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass »</TD></TR><TR><TD CLASS="quote">im 99.999% positive all the oil pressure sending unit on the back of the block does is run to the dummy light on the dash...</TD></TR></TABLE>
I'll add the .001% to make it 100%. You don't need it. Get an oil pressure gauge eventually.(my suggestion)
Re: Just curious if no oil pressure sending unit affects anything... (SOHC4life 96)
I have a gauge, that's why i removed it, i couldn't get it to seal with the sending unit, the T for the gauge, and the feed to my turbo. I removed it, no more leaks.
1 Post
the VTEC system has its own oil pressure sensor next to the VTEC solinoid. the one you used that is next to the oil filter is only for the oh **** light.
n0pinitr0us
21
04-10-2005 08:55 PM
