DSM 450cc injectors
DSM 450cc injectors
i heard about people using stock eclipse gsx injectors. i was wondering if i got a set of the DSM 450cc injectors would i be able to use them on my b16 w/an AEM fuel rail
Re: DSM 450cc injectors (JDMmicro-minivan)
search man... the answer is DEFINATELY in the archieves.
You MAY have to run a resistor box because the DSM injectors are peak and hold instead of saturated....
Unless your injectors are already peak and hold...
Also what are you running to require that much more fuel?
Re: DSM 450cc injectors (NonovUrbizniz)
you're going to be needing the resistor box and you will need to rewire. search around and im sure you can find the answer somewhere in the boosted forums
Re: DSM 450cc injectors (ADVAN EG2)
You'll need the resistor box like stated above, I'd suggest getting some obd1 injector clips.. And a way to control the injector's out put once you swap them in.
Re: DSM 450cc injectors (SiKid86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiKid86 »</TD></TR><TR><TD CLASS="quote">You'll need the resistor box like stated above, I'd suggest getting some obd1 injector clips.. And a way to control the injector's out put once you swap them in.</TD></TR></TABLE>
If you just install them bitches, you WILL run super duper ******* uber rich...LOL
