another "MY VTEC DONT WORK" thread
<FONT COLOR="red"> MORE UPDATES BELOW</FONT>
my friend just recently bought a 98 gsr (im posting it here because the integra section moves too slow) knowing that vtec didnt work.
now here's what we've tried
1. changed the oil with mobil 1 synthetic /new oem honda filter
2. replaced the vtec solenoid with a brand new one from acura
3. checked the oil pan, no dents (block seems to have never been taken out)
4. checked the ecu, same one that came with the car, swapped it out anyways with mines from gsr, same problem
5. took it out for a spin at normal temps and correct speed, still no vtec
6. checked the vss, not broken, speedo works fine
7. replaced oil pump, water pump
9. checked engine wire harness, same oem the car came with, no cuts, plugs are still good
10. checked for pins in the head, still there.
now, the previous owner said he did take off the head because he replaced a bad valve. he said that vtec was fine before that.
and yeah ive searched, the best thread was this https://honda-tech.com/zerothread?id=164863
thx in advanced
<FONT COLOR="red"> UPDATE 11.28.05</FONT>: we did a vtec switch and vtec does kick in (so we know nothings wrong with oil pressure, the head, etc) we're looking at the wire harness right now, but we're waiting on getting a new gsr harness to see if that'll work
<FONT COLOR="red"> UPDATE--2.08.06</FONT> well, we ended up swapping a new 1998 gsr motor into the dc2 chasis and VTEC still doesnt WORK. we figure its the wire harness again so we linked the wires for vtec (vtec sol and vtec pressure) straight to the ecu like a car that never came with vtec, still no VTEC. we swapped ecu again with a working one, still nothing. so we're out of ideas. i mean is there a fuse or something for vtec that just died or what.
on another note, when we unplugged the vtec pressure, the CEL came on, but when we unplugged teh vtec sol, NO CEL. so any help more would be awesome
cliff notes:
-old motor was ripped out
-new motor was installed
-still no vtec
-tried 3 different working ecu--still no vtec
-tried linking direct wires from vtec sol/vtec oil pressure to ecu--no vtec
-tried linking to switch--YAY I GOT VTEC
-but i dont want to run with a ghetto switch
any more ideas, the new motor is perfect with only 55k bought from a friend
<FONT COLOR="red"> UPDATE BELOW-2.28.06</FONT>
-i tried a vtec light with everything just running from the ecu--it WORKS @ 4400 rpm
-now i think im ive been a fool all this time-i wasnt aware (even after having 4 gsr motors) that vtec kicks in @ 4400 and the IAB's kicked in @ 5700 rpm on a gsr motor (i had a sk2 on my last buildup)
-so my problem does not lie in the vtec, but with the IAB's not working properly
-with that being said, people say that the trick to seeing if the IAB's works or not is to see it IAB actually close when you start the car (its open when its off). now when i did that, it didnt do anything. its like the IAB was stuck, now if i take off the vacuum line when the car is on, then IAB opens(actually moves, so i know its not opening when the car is off) i think this is where my problem lies
any ideas on this
color=red] 3.03.06[/color]
finally got it to work properly, the 2 vacuums (#12 and #13) were hooked up wrong under the IM but hooked up right to the proper places (FPR and IAB) so i never wouldve guessed. but i tried it and it worked. thanks for everything, after spending $2000 for new things and a new motor, i finally have things working for once
Modified by pennies_hatchie at 8:48 PM 2/28/2006
Modified by pennies_hatchie at 6:30 PM 3/3/2006
thx in advanced
cliff notes:
-still no vtec
any ideas on this
can you hook up an oil pressure guage? it sounds like an oil pressure problem to me. that's the only thing I can think would prevent it from coming on from what you said you've changed.
Location: chillin in that city called queen creek, but homes the atl
Re: (gftgrill)
dam u wasted a lot of money on all those newparts. ask the original owner is that the same herad that came with the car or did he buy it off some one maybe the plugged the oil jet for lsvtec happened to me. and check the screw slash bolt on the corner of the head above the water neck and see if there is oil pressure while the car is running
Re: (street dreams)
yeah, i figure there might not be enought oil pressure, but i dont have an oil pressure tester.
also its the same head that came with the car. and im unsure about the screw slash bolt, do you have pix of it
Re: (pennies_hatchie)
if vtec isn't working u should be throwing a cel.. are you?? as everyone says i tihnk its your oil pressure sender.. or maybe vtec just ins't wired up right.
Re: (warrick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warrick »</TD></TR><TR><TD CLASS="quote">try checking your timing. its quite possible the timing didn't get set right when he took the head off. timing off = vtec wont engage</TD></TR></TABLE>
yeah we'll go check timing then if that don't work then we don't know whats wrong..
Re: (boosted_elf)
just out of curiousity how far can you rev the motor up to when u drive it and how does it run when just cruising around town
Location: With my POS D15B2, Whereever whenever, United States
Re: (street dreams)
timing check?
oil check?
another one of those, i sold the car because it was having problems and your friend got on the shitty side of the deal
oil check?
Re: WTB... (DXK Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DXK Eg »</TD></TR><TR><TD CLASS="quote">looking for a B-series tranny in any shape or form...Let me know what you have to offer.. If you have more thing one I'll take them too</TD></TR></TABLE>
lol, wrong thread. HAHA
Re: (street dreams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street dreams »</TD></TR><TR><TD CLASS="quote">just out of curiousity how far can you rev the motor up to when u drive it and how does it run when just cruising around town</TD></TR></TABLE>
car starts up fine, idles fine, drives fine just like an ls, and is able to rev to 8200k. just that there's no vtec. the car has a 5zigen catback and intake so im sure if its there, we should be able to hear it.
Re: (MugenHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda »</TD></TR><TR><TD CLASS="quote">check the ECU, make sure it is a obd2 p73
actually its suppose to be an OBD2A p72, not p73 (thats a type r) and yes, its a obd2a p72, we even switched it out with mines from my gsr
Re: (spoonspeed)
My friend has a del sol and swapped his z6 for a b16. My other friend got his z6 and installed it in a cx hatch. The vtec worked fine in the delsol. Now that he swapped the z6 in the hatch he has no vtec. He changed the solinoid, oil, ecu, checked all the electrical you name it. He is a certified "dodge" mechanic so has pretty good car knowledge. But we can't figure out the problem. He has a chipped uberdata P28 and installed it in my friends vtec and it ran fine. He can take it to redline but without any vtec. If I left anything out let me know and I'll try my best to answer
Re: (paul vang)
I would suggest what everyone else suggested but it seems that its something other than that. Good luck with finding the problem post the solution when you do.
Re: (white4doorsi)
It's tuff because we have went through everything 2-3 times and swapped out the parts etc. It's the fact that it went out of one car and into another like that and now nothing.. Just puzzled
Re: another "MY VTEC DONT WORK" thread (pennies_hatchie)
your pick up line is clogged.drain the oil take of the headers and drop the oil pan and remove the pick up line and check it.
Re: (paul vang)
are you talking about lma's(lost motion assemblies)?
im with the oil pick up if it has been beat on oil could be clogging the pick up . run some sea foam clean the pick up , and check the lma's like paul is talkign about
