lagging problem with acceleration
sometimes when i accelerate, usually in first gear, my car lags on pickup really bad. i was told it was my fuel injectors, but after replacing them all and checking them from time to time, they seem fine, im guessing its my clutch but not sure, or maybe there is another way to check injectors that im not sure about. Any suggestions?
Re: lagging problem with acceleration (fit256nj)
your clutch would probably need to slip in order for it to be the cause, my guess is its fuel/spark related...try a tune up (cap/rotor/plugs/wires) also, when is the last time you changed the timing belt?
Re: (SkoundrelUSA)
Get some injector cleaner on a empty tank.....Makes a big difference in the line not just the injectors and if not it's just good maitanance.........
cute little bastard
Re: (ThaCivicAssassin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThaCivicAssassin »</TD></TR><TR><TD CLASS="quote">Get some injector cleaner on a empty tank.....Makes a big difference in the line not just the injectors and if not it's just good maitanance......... </TD></TR></TABLE>
Already done, didn't do anything lol
Re: (crxsi8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsi8 »</TD></TR><TR><TD CLASS="quote">Check your coil system..mine had the same problem..let it idles..and if it seems like its missfiring then its your coil sys.</TD></TR></TABLE>
yeah, seems like a coil problem. if you already replaced the spark plugs, wires etc.. then my only guess would be the coil.
cute little bastard
Re: (crxsi8)
I'm pretty sure its not misfiring, but we'll probably do the coil system anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xd69 »</TD></TR><TR><TD CLASS="quote">check your timing....</TD></TR></TABLE>
Yeah I'm looking into a timing light, just not sure which one I want
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed »</TD></TR><TR><TD CLASS="quote">air filter....?</TD></TR></TABLE>
Brand new...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">low fuel pressure?</TD></TR></TABLE>
I'll put my gauge on his today and see if its low. It should be at like 35-40ish with the hose right?
Brand new...
Re: (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">
I'll put my gauge on his today and see if its low. It should be at like 35-40ish with the hose right?</TD></TR></TABLE>
what motor? if d16, its 35-42 wot (vacuum line removed from fpr).
cute little bastard
Re: (IHateJDM)
what motor?</TD></TR></TABLE>
His, D16Z6
His, D16Z6
Re: (ApolloSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ApolloSpeed »</TD></TR><TR><TD CLASS="quote">you really put injector clean in an empty tank ????
that's what your suppoesed to do.... right before you fill up your tank with gas
12
05-12-2008 07:30 AM
Hammer01
02-20-2007 01:33 PM
