Has anyone here ran with no O2 senser at 1 point?
Old 04-23-2006, 02:04 PM
vtec25's Avatar
Default Has anyone here ran with no O2 senser at 1 point?
if so did ur car run like chet?
Old 04-23-2006, 02:05 PM
3.point.2's Avatar
i dont have an O2 sensor and my car runs fine
Old 04-23-2006, 03:01 PM
egcivic's Avatar
Default Re: (h23eg)
is ur car obd1 or 2
cuase the obd2 cars have more than one and i think can run fine without one of them
but my car the o2 went out, i got a code and my car ran like crap
Old 04-23-2006, 03:03 PM
forcefedferio's Avatar
Default Re: Has anyone here ran with no O2 senser at 1 point? (vtec25)
yeah for like a day because when i put my header on the o2 sensor was pretty much welded into the stock manifold...long story short car idled like complete *** and ran like ****
Old 04-23-2006, 03:07 PM
3.point.2's Avatar
Default Re: (egcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcivic &raquo;</TD></TR><TR><TD CLASS="quote">is ur car obd1 or 2
engines obd2, but the car and ecu are obd1. i dont have any O2 sensors in. my ecu throws an O2 sensor code, but my car runs great and i get 30+mpg on the highway
Old 04-23-2006, 04:04 PM
SVOboy's Avatar
Default Re: (h23eg)
30 mpg on the highway is pretty bad, but anyway, you can run without it, I don't see why though.
Old 04-23-2006, 06:32 PM
3.point.2's Avatar
Default Re: (SVOboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">30 mpg on the highway is pretty bad, but anyway, you can run without it, I don't see why though.</TD></TR></TABLE>
pretty bad? read my name, i dont have a d series
Old 04-23-2006, 06:35 PM
slowturbocx's Avatar
Default Re: (h23eg)
i dont run a o2 sensor d16z6 turbo, runs good 25 mpg too
Old 04-23-2006, 06:40 PM
SVOboy's Avatar
Default Re: (h23eg)
Wow, a 2.3 liter getting 30mpg highway, I'm mystified. I've never seen anything like it.
Old 04-23-2006, 06:45 PM
jadugartir's Avatar
Just get a program on your ecu that supplies a constant o2 reading... like hondata or uberdata or something, then you wont need o2 sensors or any of that crap.
Edit: btw i get 22 mpg, so dont listen to my advice
Modified by jadugartir at 10:01 PM 4/23/2006
schardbody's Avatar
i run w/out one almost all day, but i had it disabled, so i got no cel, not the best idea in the world unless you trust your tune very much.
Old 04-23-2006, 06:57 PM
Soccerking3000's Avatar
Default Re: (schardbody)
i havet ran with an O2 sensor for more than a year and i get 35+ mpg
Old 04-23-2006, 07:39 PM
egcivic's Avatar
Default Re: (Soccerking3000)
im not saying without a doubt ur car will run like crap without an o2
but mine was almost not driveable without my o2 sensor
im sure not all cars get 30+ mpg on the highway without an o2 sensor *shrugs*
you gave what your car did and i gave what mine did no need to get hostile
Old 04-23-2006, 07:43 PM
specv5150's Avatar
my car gets excellent gas &lt;PG and I have been running with basially no O2 for 1 1/2 years. I swapped to 4wire for turbo, but that didnt last long, so I went back to my regular HX ECU, but with a 4wire sensor. SO basically it isnt even reading the o2 sensor right now and drive slovely
Old 04-23-2006, 07:48 PM
Default Re: (specv5150)
well i run open loop all the time and i tuned the vacuum columns for fuel economy and use the IAT compensation along with a few other modifications.
Old 04-23-2006, 07:58 PM
schardbody's Avatar
well, the o2 only compensates 5% anyways, its not that useful, i mean 5% of 30mpg isnt much.
Old 04-24-2006, 05:14 PM
vtec25's Avatar
well mine is running like crap like its only on 3 cylinders and i get bad mpg dont know exactly cuz my speed sensor is bad therefore no speedo. plus my tps is broken off.
Old 04-24-2006, 05:16 PM
schardbody's Avatar
and your worried about the O2. you need to get the TPS fixed. your ecu is basing fuel trim solely off the map sensor right now, and its probably pig rich, which will kill the o2 eventually if not already.
Old 04-24-2006, 05:26 PM
KoLRaNcH's Avatar
Default Re: (h23eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23eg &raquo;</TD></TR><TR><TD CLASS="quote">
engines obd2, but the car and ecu are obd1. i dont have any O2 sensors in. my ecu throws an O2 sensor code, but my car runs great and i get 30+mpg on the highway</TD></TR></TABLE>
That is damn good, I am jealous...I don't get 30.
Chee_dog
07-20-2007 08:21 PM
vtec69
12-20-2006 03:53 AM
iheartmyej8
06-01-2006 05:15 AM
Ddogz15
04-25-2004 06:08 PM
schtozo
02-18-2004 10:46 AM
Quick Reply: Has anyone here ran with no O2 senser at 1 point?
